Thread: buy or build solar heater?
    Jun 2008
    Bruce Peninsula - Ontario
    44
    Does anyone have good plans for building a solar collector or should i buy a ready made one. Is the sungrabber any good? or any other recommendations?
    Thanks
    20 X 40, 28000 gal IG cement bottom, steel sides, vinyl liner, Pentair 4X160 pump, sand filter, SWG, Titan heat pump, coluorlogic and fiber optic. concrete-exposed aggregate deck
    1 skimmer, main drain, 4 returns ( 2 in stairs ) JEWEL LIKE WATER thanks to TFP!
    Re: buy or build solar heater?
    I would buy the standard 4x20 panels and then install them yourself. Standard solar panels are very efficient and quite inexpensive. It isn't practical to make anything with as good efficiency unless you use materials that cost more.
    Mar 2007
    Virginia Beach
    272
    I have the sungrabbers and they work fine and are relatively inexpensive. I believe that they are approx 100ish per panel.
    6000 gal inground fiberglass
    1.5hp pump / sand filter
    Liquidator
