Thread: New Pool Running about 40 Days Pressure up?????
    Sep 2015
    Mesa, AZ
    305
    Does a new pool typically require a cartridge cleaning soon after start-up? This is my first cartridge filter. I have previously owned a DE filter. My system have been running approximately 40 days and the pressure is up. I keep the skimmer clean, and the leaf vac basket clean.
    Thanks
    Josh
    Freeform /620 Surface/110 perimeter/20k gal/ Raised bond beam/Baja shelf (2)//Pentair- Intelliflo VS pump, Pentair Whisperflo 1hp// Easytouch, C&C 520 Cartridge, Intellichlor SWCG// A&A- Magnasweep in-floor, LeafVac, Venturi Skimmer,// Mini-pebble (Aqua Blue w abalone shell)//4 Pentair Globrite LEDs//3 sheer descents//Travertine coping and decking.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: New Pool Running about 40 Days Pressure up?????
    It's likely coated with plaster dust from the brushing you should have been doing with the startup.
    Sep 2015
    Mesa, AZ
    305
    Yes I was brushing daily for the first 20 days. I suspect the cartridges are coated with plaster. Looks like I'm cleaning today.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,494
    Josh,
    I have a slightly smaller pool but with the same pump and filter. Pool has been running since April 2015 and the first time I cleaned my filter was about 6 months later. I was worried because my pressure was not noticeable higher and just wanted to check what the filters looked like before winter got here. The filters were clearly dirty but nothing like the DE filters I've had in the past. I had very little plaster dust when my pool was new, so if you did, then Richard is probably right.
    I'd be curious to know what your "clean" pressure was and what it is now, as well as at what pump speed you are taking the reading.
    and.. if you have taken apart and cleaned a DE filter you should be right at home with your cartridge filter. It takes me a little longer to clean the individual cartridges, but I don't need quite as many cuss words as I needed to reassemble the DE grids.
    Jim R
