Results 1 to 8 of 8
Thread: Jandy heater? Because I can't find a 9 inch flue for the raypak heater
    Oct 2015
    Dallas
    123
    This has been more than annoying for me for the past month. So decided to go with a Raypak heater (as everybody here loves). I have a shed protecting my pool equipment (no big deal thing has a door and a 8 foot ceiling). I have tried to find this recommended 9 inch flue for the raypak to vent it out the ceiling but nobody has it, i can't find it, and I had 3 separate pool companies come back to me saying they can't do it. The 4th actually came back and said they could, but they could not find the 9 inch flue, and they themselves "apparently" contacted raypak regarding this with zero results...
    ....am I missing something here?
    Regardless I am giving up on this dream of the raypak and am looking at the Jandy unless someone happens to have any guidance regarding venting this raypak through a ceiling.
    Inground Gunite/Plaster pool with spa. Estimated 31,000 gallons.
    Oct 2015
    Katy/Texas
    411
    Re: Jandy heater? Because I can't find a 9 inch flue for the raypak heater
    Is this what your looking for?
    Raypak Outdoor Stack | 009837
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Oct 2015
    Dallas
    123
    (shrugs). I'm guessing so. Maybe my big headache here has solely been a name issue (why a 9 inch flue vs just calling it a stack).
    This thread can be closed, chucking the raypak due to vent headache.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    The size of the vent pipe isn't absolutely critical. I believe I responded in your last thread and mentioned going with either 8" or 10" B vent. The whole purpose to to have a sufficient size vent to allow the heated gases to naturally escape in their own convection column. Smaller vent pipe may inhibit this flow unless there is a blower installed as well (added expense and another potential fail point). Both of those vent sizes are far more common and much easier to obtain.
    Don't get rid of the Raypak. They are great heaters. I think you are over complicating the issue just a little bit.
    Your best bet for online sources would be a fireplace insert wholesaler. Check out efireplacestore.com or hearthsidedirect.com. Both stock 8" and 10" all day long.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    ps0303's Avatar
    Jul 2011
    FL
    3,693
    Contact a HVAC company and explain what you need done. They can make up what you are looking for.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    *hears crickets*
    I think he's gone...
    Review
    A flue is the closed vent pipe...
    a draft hood or stack-top, is the open part that helps the gasses travel up and out, usually installed nearest the appliance.
    You never want to make the flue or any part of the exhaust system smaller than the collar (the 9 inch part). Unless it is forced, like with a fan. You wouldn't want to trust a draft hood designed to effectively exhaust 9", to deal with 8". I won't tell you it wont work, but would you want to go to jail because of it? It may be in a well vented room, maybe not in a living space, but either way, you are liable for the install if anything happens. That's why i don't do venting. I can't afford the extra insurance! And i wont sell a heater in a room unless an HVAC guy is meeting me on the day of install to do the venting.
    Raypak made the 9" collar probably knowing that it is an unpopular size, and that you would probably just go to a 10" making great flow through the flue, thus making them heroes.
    Anyone know how the jet engine was invented?
    Factory Warranty Station for:
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    I wasn't aware the exhaust was 9" on the heater. I've only vented the master temps and they require a 4"-8" adapter to connect to the B vent. Had I known the exhaust port was 9" on the Raypak, I never would have offered the advice of an 8" vent pipe
    -Brian-
    POOL BUILD
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    No worries Brian, the post was advice for all.
