Thread: Plugging fill line for the winter
    Dec 2015
    Edmond OK
    8
    So, we were told by the pool builder to plug our fill line for the winter -- the fill line feeds into the pool, under the water line. They said to use a shop vac or air compressor or something to blow air into the line and then put a plug (which we were given) into the hole where the water comes out, under the water. We think we did this last night, meaning, my husband blew air into it using a shop vac and I saw bubbles come out into the water, and then I put the plug into the hole. My question is -- since the hole is underwater, there is pretty much no way it was completely free of water -- is that okay? I mean, some water probably got pushed back in or trapped when I was putting the plug in. I am just not understanding this concept. Are we actually worse off now in that any lingering amount of water in the fill line is going to be colder than the water in the pool, because it is no longer in contact with the water in the pool, and thus MORE likely to freeze? Does this make any sense?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Plugging fill line for the winter
    Welcome to TFP!
    It depends on how much water backed into the line, and how deep your frost depth is. I don't know what that is around OKC, but it shouldn't be hard to find out. Normally, when lines are purged of water for pool closings, they are done when the pool water level is lowered below skimmers and return lines. Sorry I'm not more help.
    Essential Links:
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Sometimes they put RV antifreeze in the line after its plugged.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
