Thread: circulation pump (ozonator ?) making noise, (with movie).
    Aug 2015
    Arnhem/Netherlands
    109
    I have a new spa now 8-01-2016, the other one (10 months old) is back to the dealer.
    I have one issue
    The 24 H circulation pump is making noise and bubling.( the older spa did that not)
    We have disconect the hose from 1 one-way valve from ozonator (it is in the hose) and i put my vinger on it.
    Then the noise and bubles are away.
    Ozonator pump bubling - YouTube
    My spa is 225 gallon (ca 900 ltr)
    Factory is Caldera
    Above ground
    6 months old now.
    Aug 2015
    Arnhem/Netherlands
    109
    Re: circulation pump (ozonator ?) making noise, (with movie).
    See picture.
    If i put the vinger on the hose by red arrow (and closed it) then the problem is solved.
    Upper red arrow is the one direction valve this one is OK i have check it.
    Factory is Caldera
    Above ground
    6 months old now.
    Aug 2015
    Arnhem/Netherlands
    109
    Nobody
    Factory is Caldera
    Above ground
    6 months old now.
    Aug 2015
    Arnhem/Netherlands
    109
    Factory is Caldera
    Above ground
    6 months old now.
    Aug 2015
    Arnhem/Netherlands
    109
    The problem is solved, the ozonator was the problem.
    I have put him out and closed the hose
    Factory is Caldera
    Above ground
    6 months old now.
