Thread: how/where do you dispose your solar pool covers?
    Jan 2015
    San Jose, CA
    237
    I don't think they're recyclable so where do you dispose them?
    SF Bay
    ********20,000 gallon IG Fiberglass, DE Filter, Hayward Max-Flo VS, Taylor TF-100 Test, Circupool RJ-45********
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: how/where do you dispose your solar pool covers?
    They are recyclable but not everywhere can accept them. I believe most are made from LDPE 4. Check with your manufacturer on the actual material and call your local recycling center (centers, if necessary) to see if they will accept the material if you bring it in.
    Isolated Spa - 345 Gallons
    Jul 2015
    Clearwater, FL
    83
    Shouldn't you have a bubble wrap pop party first?
    16K gallon IG exposed aggregate pool with Aquarite SWG T15 cell, Hayward C1750 filter, EcoStar SP3400VSP pump, H400FD pool/spa heater, Polaris PB4-60 booster pump, 280 pressure cleaner, Hayward Super II spa pump and Air Supply Silencer spa blower
    Jun 2012
    western NY
    1,561
    Quote Originally Posted by ThomasG View Post
    Unfortunately, that is the reason most are bad...the bubbles are already popped. I got rid of my last one by cutting it into manageable pieces and topping off my trash bag each week.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I recently heard that with the extreme drop in crude oil prices, recyclers can't sell their plastic. New plastic is cheaper than recycled. So some (or much) of the plastic sent for recycling is currently going into landfills. Cheap oil has its drawbacks.
    chiefwej
