Results 1 to 9 of 9
Thread: Help Yellow Water
    Jul 2015
    Poway, CA
    58
    Help Yellow Water
    Hi,
    So my pool water just had RO completed. Water was balance perfect with stabilizer added. Now we had a huge rain storm in San Diego area and my water is yellow from the soil runoff. What do I do to get back?
    Thanks for the help!
    27K Gal, IG Plaster, Hayward EcoStar Variable Pump, Pentair DE FNS Plus Filter 24, Hayward AquaRite with extended life T-CELL-15
    The Pool Cleaner Sweep
    Build in 1969
    Water From City
    TF-100 Test Kit
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Help Yellow Water
    Unfortunately a whole lot of filtering, brushing and patience. Letting it settle then a very slow vacuum may help hasten the process.
    Is it cloudy yellow or is it clear yellow? I assume its just dirty and not that iron or something else was introduced, but others can help if that is anticipated. Good luck.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Jul 2015
    Poway, CA
    58
    Quote Originally Posted by Pool Tool View Post
    Good news there is no dirt. Just clear yellow water like urine.
    Build in 1969
    Water From City
    TF-100 Test Kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Can't be of much assistance without test results from a recommended test kit.
    Usually it's a SLAM procedure that's on the menu.
    Isolated Spa - 345 Gallons
    30,421
    Got a pic? I doubt that is from soil runoff. Assuming it's not, test results are needed.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'd be interested in the pH and if you've added any acid just prior to this.
    Essential Links:
    Jul 2015
    Poway, CA
    58
    So my water was crystal clear and balance yesterday until last nights major storm which we had over 2 inches or rain and we live on hill so water goes from one neighbor to the next.
    Numbers:
    FC 2.5, I going to add 2 quarts of liquid chlorine.
    CC .5
    TC 3
    CH 425
    TA 110
    CYA 40
    PH 7.8, I going to add 2 cups
    Thanks for the help.
    Build in 1969
    Water From City
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Sounds like a plan. Could be runoff (it would be awful to discover the upstream neighbor just applied Iron Sulfate to his roses!) or there could already be Iron in the water and the aeration from the rain raised pH enough to cause it to precipitate. Adjust pH, raise FC, and run the filter and see what happens.
    Jul 2015
    Poway, CA
    58
    Lower or raise PH?
    Thanks for your input! The pool was perfect with no metals and completed the RO prior.
    Very frustrating!
