Page 1 of 8 1234 ... LastLast
Results 1 to 20 of 141
Thread: Signed this morning, new build in Humble, TX
    Nov 2015
    Humble
    101
    Been lurking and learning here lately. Also submitted plans to the HOA. Should start digging later this month. Spec's are:
    Geometric Gunite Pool – 30 ft. x 16 ft., 385 sq. ft., 92 ft. perimeter
    3/8 in. rebar on 8 in. centers with continuous bond beam of 1/2 in. rebar
    4,800 psi gunite, 12 in. thick floors, 8 in. thick walls, 16 in. x 12 in. bond beam
    Pool Depth – 3.5 ft. to 5 ft.
    Coping – Flagstone with chiseled edge
    Ceramic waterline tile.
    Interior Finish – Pebble Sheen – Blue Surf with Abalone Shell
    Tan Shelf – 8.5 ft. x 3.5 ft. tan shelf capped in flagstone to match pool coping.
    Raised Beams – (1) 23 ft. x 1.5 ft. x 12 in. high raised beam. (2) 14 ft. x 1.5 ft. x 16 in. high raised beams. All beams coped to match pool and sides clad in ledge stone.
    Water Feature – (3) 3 ft. wide flagstone scuppers in 23 ft. raised beam. Scuppers ran from pool circulation system with Jandy valve.
    Stone Sealing – All pool stone and tile work will be sealed with silicone based penetrating sealer.
    Decking – 319 sq. ft. new stamped concrete decking, 4 in. thick with rebar on 16 in. centers 4,000 PSI “5 sack” concrete. Fiberglass fibers added to concrete for increased strength. Deck rebar tied to pool rebar for strength. 110 lf. of 4 in. PVC drain pipe with pool overflow. Gutter downspout connections, (5) area drains. Customer to choose pattern and color. Epoxy fill expansion joint between decking and coping.
    EQUIPMENT
    3 hp Pentair InteliFlo Variable Speed Pool Circulation Pump.
    Dual Intermatic Timer with Sub Panel
    420 sq. ft. Pentair Cartridge Filter
    Rainbow 320 Automatic Chlorinator
    Plumbing and booster pump for future pressure side cleaner.
    (2) Pentair GlowBrite color changing LED pool light fixtures.
    (7) 1.5 in. returns with adjustable jets in pool.
    (2) Skimmers with 1 dual main drain on independent lines to pump with Jandy valves.
    Flovis FV-C inline flow meter.
    All pool plumbing schedule 40 PVC.
    All pump connections CPVC.
    Auto-fill line with Anti Siphon.
    All drain covers are VGB compliant.
    Custom designed pool
    Assistance with HOA submission
    All start-up chemicals
    Repair of side walk and curb if damaged during pool construction
    Pool school
    Professional cleaning equipment (pole, net, vacuum head, vacuum hose and brush)
    Chemical testing kit, Taylor K-2006
    Clean up and grade after gunite.
    Clean up and grade upon completion.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,425
    Re: Signed this morning, new build in Humble, TX
    Love it! The bench will be a very popular area!
    Do you have any shoots of the "real" yard it is going in?
    Make sure to get model numbers for all of your equipment in writing.
    Kim
    Oct 2015
    Humble, TX
    64
    Nice! 🏽
    Dec 2015
    Severna Park, MD
    78
    Congrats! Nice plans
    Sent by incredibly fast electrons
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Nice design, interesting landscaping opportunities with the back corners.
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Love the design! Congratulations! Make sure to post lots of pictures!!
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Great design. I really like the colors on this diagram, if this is what you decide. Nice pool!!
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Aug 2014
    Houston tx
    2,524
    I love the simplicity of your plan! Nice!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Nov 2015
    Humble
    101
    My builder has an aggressive build schedule. Should start posting pictures late next week.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Have you had a pool before and do you plan on using the "TFP' method to maintain it or chlorine tablets ?? I ask because in your equipment list you have a Rainbow 320 Automatic Chlorinator that would be used for tablets. It's sometimes handy to have a floater to use them if you're going to be gone a few days but using tablets as the main source of chlorine in your pool can cause problems with high CYA.
    Solar Blanket, Well Water, Borax Added. 68°
    Nov 2015
    Humble
    101
    Yes the BBB chem's.
    Nov 2015
    Humble
    101
    Had a little pre-build work done today. Had the big magnolia tree in the center removed along with three knock off rose bushes and a hawthorn tree on the left corner of the lot "not in picture. Hated to remove them but as the saying goes "you have to break a few eggs to make an omelet".
    Jul 2012
    Tallahassee, FL
    30,425
    I have a sad for the magnolia tree. BUT for a pool it will be worth it.
    Kim
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Yeah, we lost a tulip magnolia to old age and a happy woodpecker behind our quintessential ranch house and it broke my heart a little. So many years of pictures of our boys below that tree...
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Trees are definitely hard to see go, especially at our house where we specifically chose this lot for the shade the trees provided for our kids in the backyard. But two red oaks sat just where our future pool will go, and we cut them down. Only the stumps remain for the excavator to extract. At least those will be two fewer oaks to shed their leaves and acorns!
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Nov 2015
    Humble
    101
    Stake out complete. Pending weather: dig tomorrow, rebar and plumbing stub out on Friday and gunite on Sat.
    IG Gunite, 16' x 30', 3 1/2' - 5' deep, ~11K gal, Pebblesheen, Intelliflo VS pump, Clean and Clear 420 Filter, LED Color Lights, Taylor K2006 Test Kit.
    Build thread http://www.troublefreepool.com/threa...d-in-Humble-TX
    Jul 2012
    Tallahassee, FL
    30,425
    NICE!
    Did you measure????
    We just had one where they did NOT mark it right BUT he caught it because he was there to watch.
    Kim
    Nov 2015
    Humble
    101
    Quote Originally Posted by kimkats View Post
    NICE!
    Did you measure????
    Kim
    Yes indeed.
    Jul 2015
    Frisco TX
    63
    Nice design love it. I'd be tempted to want to jump off that roof into deep end
    Free-form IG Gunite | Length 32 ft | Width 19 ft | Depth 3.5-5-7 | 14,462 gallons | Raised Spa 6.5 x 9 | IntelliFlo VS Filter pump 2" | Pentair FNS Plus 60 sq ft D.E. filter | 320 inline chlorinator w/UV & IC 40 SWG | Dolphin M5 | Easy Touch 8 | TF-100
  20. Back To Top    #20
    Nov 2015
    Humble
    101
    Excavation started bright and early this morning at 7AM. They were finished by noon. Rebar and plumbing stub-out tomorrow and gunite on Monday.
    Hanna supervising.
    Equipment pad
