Results 1 to 11 of 11
Thread: RE: liquid chlorine tank/pump installer in dallas-ft worth area
    Dec 2015
    arlington, tx
    100
    is there anyone in this area who will install a liquid chlorine system in this area?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: liquid chlorine tank/pump installer in dallas-ft worth area
    You might see if one of the service people who put automation systems in will do it. Be prepared for them to tell you all sorts of bad things about using liquid chlorine however.
    Essential Links:
    30,419
    Adding to what Patrick said, there are few installation people on here......pool owners mostly.
    Mar 2015
    Sugar Land , TX
    424
    Not sure of your DIY skills but you can purchase a Stenner pump with tank and all you need to do is drill and tap a hole for injection. It really is that simple! There are plenty of forum members including myself who have installed a Stenner and can help you with it. If I am not mistaken there is a guy in Dallas area who did it within this past year.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Dec 2011
    Prosper, Texas
    124
    oddly enough I bought my 15gallon blue tank from a place in Arlington I found on craigslist. its a really easy DIY install.
    21,000 gallon pool w/spa, Pebble Sheen, Hayward EcoStar variable speed filter pump, Hayward DE6020 Filter, Hayward 400FDN Heater, Stenner pump with 15 gallon tank, Clear O3 ozone system, Hayward Goldline PS-8 controller, Hayward 6060 cleaner pump, Polaris 280 cleaner, Hayward EcoStar variable speed water feature pump.
    Dec 2015
    arlington, tx
    100
    how do you put the pump on a timer so as to be in synch with the pool pump timer?
    Jul 2014
    Cypress, TX
    8
    I bought an electric timer at Lowes for outdoor use. I manually set it using the start/stop inserts. I typically set it to start an hour after the circulation pump starts and make sure it is off before the pump stops. Works great.
    15,000 Gal.; Pebble Sheen; Pentair Intelliflo 3 HP VS; Pentair Clean and Clear 420 cartridge filter; Polaris 380; Taylor K-2006 test kit; liquid chlorine; borates
    Jul 2015
    Central Valley CA
    1,107
    If you get a fixed rate pump I would suggest a digital timer since run time is your easiest dosing adjustment option and a few minutes one way or the other can make a big difference over a period of days. If you have an adjustable rate pump probably does not matter so much, but I have heard the adjustables make a bit more noise.
    Also I noticed you have iAquaLink if the control panel you have has an unused AUX relay you can connect the Stenner pump to that and assign runtime through the system, If it is like my system you can even go as far as programing the system so that the filter pump must be on for the Stenner relay to activate.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Dec 2015
    arlington, tx
    100
    can the pump be run with my iAqualink???
    Jul 2015
    Central Valley CA
    1,107
    If you have an unused AUX relay then yes the iAquaLink can control the pump either scheduled and/or manual on/off from the web control. Open your control panel at your equipment pad and take a look inside you will have 4 or 8 relays depending on what system you have, if any of them are empty (no power wires other than the small red and black coil wires the make the relay work) then you should be able to connect the pump to the panel. You want the relay to be connected to a GFCI circuit either a breaker or the output of a GFCI outlet, then out to the pump. If you are not comfortable with electrical tasks like installing breakers or outlets in outdoor locations I would hire it done. It would be a small job for any electrician or pool service company. I would go with the pool service if you can find one willing, they will be familiar with the relays and how to program the panel so that when the Stenner is on the filter pump is on. As was said above be prepared for them to try to talk you out of it usually in an attempt to sell you whatever system they use.
    Dec 2015
    arlington, tx
    100
    thanks
