Results 1 to 10 of 10
Thread: Robot recommendations for $900-$1k
    When is the best time to buy a robot? I am looking for one as well. Also, is it worth it to jump to the robots in the 9 - 1k range? My wife gave me the goahead to spend up to that much just trying to get the most bang for the buck for my money. Presently looking at the Dolphin Nautilus Plus...
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Dec 2014
    Riverside California
    482
    Re: Robot recommendations for $900-$1k
    Check out the Dolphin Triton Plus. I got one last month and it works great. This cleaner has dual motors and split brushes so it can turn on a dime, and top loading filters that are very easy to remove and clean. Comes with a caddy (required in my opinion) and a remote control for $1049 with free shipping and no tax. Here is the link to Sunplay.com where I got mine. They are an excellent on line vendor that I have always been very happy with.
    http://www.sunplay.com/dolphin-triton-plus-pool-cleaner
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Quote Originally Posted by gary300 View Post
    so what is the advantage of a caddy is it just easier to carry? I can get a nautilus plus for like 690 just trying to see if its worth it to step up to the dolphin triton plus. What else do you get other than the caddy and remote for the extra 350 bucks?
    Bel Air, MD 21015
    Dec 2014
    482
    The caddy makes it a lot easier to store and carry, plus provides a place to store the cable and power supply. Another thing is that you should not store the robot on its tracks or they will flatten out. The caddy provides a raised area to lift the robot up during storage. The Triton plus has dual motors and split brushes to make it more maneuverable to get into tight places. It also has a 2.5 hour cycle time and optional 1 hour quick clean cycle that does the floor only. The Nautilus would do the job for you, but I opted for a few more features.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Dolphin Oasis Z5.
    The Caddy and remote are excellent to have.
    Essential Links:
    Dec 2014
    482
    Quote Originally Posted by Patrick_B View Post
    Dolphin Oasis Z5.
    Oasis Z5, Triton Plus, Explorer Plus and Supreme M5 are all the same units, just different markings.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The Supreme M5 has a bottom brush and Pro Remote/Features, so it is different.
    Essential Links:
    Dec 2014
    482
    You are correct, my error. Another post had the M5 as equivalent to the Z5 but that is not the case.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    No worries, just sayin for those looking to buy. And there's a reason they run $1500
    Essential Links:
    Messman750's Avatar
    Jun 2015
    Groton New York
    34
    Dolphin m200
    32x16 inground chlorine. 23000 gallon with diving board
    vinyl liner 1hp hayward super pump. Waterway sand filter new in 2014.
    maytronics dolphin m200 robot. I live in central NY.
    TF100 kit Taylor speedstir. Sonos audio
