Results 1 to 9 of 9
Thread: Where to buy pavers in Austin TX?
    May 2012
    Austin, TX
    140
    Any suggestions?
    David
    ~23,500 Gallon In-Ground Plaster Pool, Intelliflo VS+ Pump, Hayward 4820 DE Filter, IntelliChlor IC40 SWG
    Jan 2015
    Austin, TX
    1,095
    Re: Where to buy pavers in Austin TX?
    We got ours from Custom Stone Supply. They are huge and have a ton of stuff. If you go visit they are really helpful and will walk you out in the yard and let you take samples. Plus they have quite a large assortment of displays setup. It is the largest setup of displays and in stock pavers I have seen in Austin and I have been to probably 6 stone yards during my pool build. They do carry Belgard so I think they might be slightly more pricey than the pavers you get at Home Depot/Lowes/Walmart. It doesn't hurt to go look.
    My entire pool is done with Belgard products (walls/deck/coping) if you check it out.
    Yet another Texas pool build!!
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    Nov 2013
    Central Texas
    113
    I am in the process of trying to figure out what material I want to redo my deck and found this local company Welcome To Stone Creek Pavers. I have no idea what the quality or cost of the product is but looks interesting. Not sure if QDI stone is still around either. If you want leuders slabs I would recommend cobra stone.
    28k gal/raised spa, IG quartzscape, WhistperFlo 2 speed B2984T,DEV60 filter,Lxi400 NG heater, Polaris 280 cleaner, DIY Chlorine injection, Build completion 7/2013
    May 2012
    Austin, TX
    140
    Quote Originally Posted by JonnyB View Post
    @JonnyB I am picking up samples from Stone Creek tomorrow. Those pavers look awesome. Will let you know how it goes.
    May 2012
    Austin, TX
    140
    I like these pavers and coping. They might even pass the wife test.
    May 2012
    Austin, TX
    140
    Wife picks the graphite. I know it's dark but she's the boss. It's almost exactly the color of the stained concrete deck we had to demo.
    Nov 2013
    Central Texas
    113
    Nice! Shoot I should contact them and get a commission hahaha
    Aug 2014
    Houston tx
    2,524
    You might want to buy a larger piece and leave it in the sun to see how hot it might get, keeping in mind that this is winter and it'll get hotter in summer.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    May 2012
    Austin, TX
    140
    Quote Originally Posted by Marlahoutex View Post
    Yeah, I'm a bit concerned about the heat - especially since the pool coping will be the same color - but we have a covered/shaded area and a small wood tanning deck that shouldnt get too hot.
    I spoke to Stone Creek and they think the light and dark grey are similar in how hot they get, and a customer (in TX) just built a pool with the dark grey.
    I am trying to get in touch with that customer to see how hot it gets - but I can tell you that this is almost the same color as our
    existing pool deck (and our house, our kitchen floor, the walls in our living room, and our cat, lol). My wife loves those dark greys.
    The old deck - the only people crazy enough to have a dark grey pool deck in Texas
