Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Stenner pump vs the Liquidator
    Dec 2015
    Newington, Connecticut
    116
    I'm looking to adopt the TFP method of sanitizing my pool this spring and was wondering what everyone thought about the Liquidator or the Stenner pump. I currently like the ability to dial in my chlorine feeder but want to use bleach instead. Especially when on vacation mainly.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Stenner pump vs the Liquidator
    Let me preface with the fact that I have neither, but if you like control to dial it in I think you will lean towards a Stenner. There is lots of info on Stenner installs in the forum and they seem pretty rock solid. Good luck and welcome.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Apr 2013
    Sacramento, CA
    2,769
    I had a Liquidator and have a Stenner. The Liqudator works off the suction created by your pump to infuse chlorine from a mix tank into your pool. They are a passive system. Easy to install and generally easy to maintain. Two limits on the Liquidator.
    First they have problems with variable speed pumps. At low speed many systems won't generate the suction necessary to cause the Liquidator to work. Solar systems create further confusion because when it goes on you are infusing more chlorine then the days it does not.
    Second, all liquid Chlorine has salt. The salt tends to precipitate out in the mix tank and has to be removed periodically. ( not a fun job) If you don't remove it it clogs the lines and there is no suction. Some folks (like me) have a situation where no mater what you do salts or other white stuff clogs the lines and prevents the system from working. Cleaning the lines every two weeks is not my idea of fun.
    Stenners are more expensive. But they can be adjusted both from a time and volume and don't rely on your pump. You can control it with a time clock, your pool timer or the pool automation. With a fifteen gallon tank you would have almost a month's supply of chlorine. (I wouldn't leave the pool that long)
    Stenners downside is that they are more expensive and complicated to set up but not really very technical. You have to do periodic maintenance on them at least every 2 years. Their biggest downside is they make you complacent and cause you to ignore your pool.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,517
    gwegan has hit the prime problem with the liquidator - variable speed pumps.
    If you want to be able to dial in things, you are going to want a Adjustable Output High Pressure Stenner Pump
    My Stenner Install - July 2014
    Support the site
    Dec 2014
    Riverside California
    485
    I prefer the fixed rate 10 gpd stenner because it is less complicated and does not make a clicking sound as the adjustable one does. It can be precisely controlled using a digital timer if you do not have automation.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Dec 2015
    116
    Great information thanks, can the Stenner pumps be installed outside exposed to weather and Sun?
    May 2014
    Franklin, NC
    9,517
    Quote Originally Posted by Andrew Howard View Post
    Yes, there is an optional rain shield that mounts above the pump.
    Support the site
    Apr 2013
    Sacramento, CA
    2,769
    They are chemical pumps designed to be installed outside. With the cute rain shield they do fine. My problem is rain filling the overflow reservoir of the Stenner tank. So if you use a Stenner tank I'd build some kind of roof.
    Also while I do notice the clicking, its not that noticeable. I have it set to run in the morning when no one is in the outdoor dining area where the pool pad is located.
    Dec 2015
    116
    My pool mechanicals are in a location where it gets full sun most of the day. Would this be a concern with either a stenner or liquidators chlorine storage tank? I'm thinking that the stored bleach or liquid chlorine would degrade in this location.
    Apr 2013
    Sacramento, CA
    2,769
    Both have opaque tanks so in theory it's ok. But I would try not to put either in direct sun.
    Aug 2014
    Shallotte, NC
    693
    I have the Liquidator and I feel that there is a Stenner in my future. Generally, I prefer simple to complex, but there are too many variables involved to expect the Liquidator to predictably meter chlorine, whether you have a variable speed pump or not. The Liquidator will inject somewhat of a base line of chlorine in the pool, but you can expect to fine tune things by hand....
    Dec 2015
    116
    I was reading older posts on the liquidator and saw that tfp members can get the system at a discount. Does anyone know if this still the case? Also an upgrade 3/8 is available any feedback?
    Dec 2015
    116
    When you refer to the high pressure model I'm assuming the 100psi unit vs the 25 psi unit. Are these the max ratings they can handle due to the pool pump pressure? I am looking at the 45MJL1 or most likley the H for high pressure. .2 - 3.0 gpd. The low setting would be great for my pump run time.
    Aug 2014
    Shallotte, NC
    693
    My experience:
    The Liquidator comes with 1/4" tubing and it is undersized. All of the 3/8" upgrades vastly improve the efficiency of the unit, but being supplied by a third party, are not covered under warranty. As provided, the Liquidator fittings will leak because there is a thread mismatch.... the 3/8" fittings are not the proper thread, either, but they will likely stop the leakage.
    Mar 2015
    Sugar Land , TX
    430
    I put my 15 gallon tank inside of a garbage can. Made a big difference in how hot the 15 gallon container was getting. Now it is cool to touch and seems the chlorine stays better.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Dec 2015
    116
    Tim is the high pressure pump needed due to pool pump pressure? I found one on chemical world.com, do you recommend a specific supplier, and also did you buy the tank through the same manufacturer?
    May 2014
    Franklin, NC
    9,517
    yes, you don't want the pool pump to overpower the Stenner and push water back into the tank. Plus, the HP pumps come with a check valve to totally prevent this from happening.
    I purchased my Stenner from USWatersystems, but that was based on their price being best at the time. I don't think many companies stock,the pumps, but rely on drop shipping direct from Stenner.
    Stenner does make a nice tank that the pump will mount directly on, but it is expensive. I just pruchased a used food grade 15 gallon barrel, kind of,like this: 15 Gallon Barrel/Drum, Plastic Barrels, Plastic Drums, Metal Drums, Plastic Totes, Plastic Storage Containers - ArizonaBarrels.com
    Support the site
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Both the Stenner 25psi and the 100psi models work equally well. For acid inaction, lower GPD model preferred over the higher GPD model. Just the opposite if you are injecting chlorine.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    Dec 2014
    485
    The Stenner pump and tank combo unit is a very convenient setup. Get the gray tank. You cannot see through it, but it does protect against UV. I just use a dipstick to see where the level is.
  20. Back To Top    #20
    GoGrabTheNet's Avatar
    Dec 2015
    Phoenix, AZ
    64
    Quote Originally Posted by Jaimslaw View Post
    As a general rule, one should opt to get the 100psi models of Stenner pumps as the pressure-side of some filter systems could be between 18-25psi, right? I guess this is measured inside the filter tank, i.e. the PSI gauge on top. However, 25psi seems as if it'd be cutting it too close. Wouldn't it be better to always give yourself maximum headroom, i.e. always opt to get the 100psi model?
    Another question: the Stenner pumps are rated in "gallons per day" (GPD). So this means that if the pump were to run continuously, for 24 hours straight, then a total of 3 gallons of liquid would be dispensed. Is this correct?
    13k Gal. PebbleTec IG pool : Pentair IntelliFlo VS pump : Hayward 8-cartridge filter system : A&A in-floor cleaners : Jandy 115k BTU heat-pump : A&A auto-filler : Stenner 45MPHP10 auto-chlorine feeder : BBB Method
