Thread: TA in PoolMath—CYA corrected or not?
    Dec 2015
    arlington, tx
    100
    i have been using the TA in the calculator without CYA correction. am i wrong? should i be using the CYA-corrected TA number instead??
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: TA in PoolMath—CYA corrected or not?
    You should record the test results as they read and not make any adjustments, so the way you have been doing it is fine.
    Love TFP? Become a
    TFP Supporter!
    Dec 2015
    arlington, tx
    100
    thanks for the help
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Cya is really negligable. It does have titratable alkalinity, but it is very, very insignificant. It doesn't truly play in...not in any practical sense where it effects CSI.
    Essential Links:
    Dec 2015
    arlington, tx
    100
    thanks for the help. taylor's test kit instruction book made it appear important to me because they devoted an entire page to it, including a formula and correction for pH.
