Results 1 to 13 of 13
Thread: ventilation/space under spa???see pictures
    Aug 2015
    Arnhem/Netherlands
    109
    Hello is it important to have ventilation under the spa?.
    And what will i choose?, tiles 60x40 cm about 12 PCs.
    Or rubber tiles
    My spa is 225 gallon (ca 900 ltr)
    Factory is Caldera
    Above ground
    6 months old now.
    Nov 2015
    VT
    85
    Re: ventilation/space under spa???
    I can't imagine why it would need ventilation.
    Hot Springs Sovereign (1999?)
    Aug 2015
    Arnhem/Netherlands
    109
    Maybey for the wood, if you see the picture of my spa then jou see that the wood is on the ground (always wet)
    Factory is Caldera
    Above ground
    6 months old now.
    Nov 2015
    VT
    85
    Re: ventilation/space under spa???see pictures
    To keep that toe kick dry I'd guess that you'd need to raise the tub onto a platform that is smaller than the footprint of the tub so that the toe kick would be off the floor and completely exposed to the air.
    Aug 2014
    Shallotte, NC
    693
    I see a no-win situation. I think ventilation is a good thing, especially if you are in a moisture prone area. However, too much "space" underneath the structure and you are inviting all manner of critters to set up housekeeping....
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Alot of people recomend firebrick.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Aug 2015
    Arnhem/Netherlands
    109
    Banditing,
    Can jou explain what do jou mean with firebrick? (i,m from the Netherlands) if i use google translate then the answer is VUURSTEEN?????
    Factory is Caldera
    Above ground
    6 months old now.
    Aug 2014
    Shallotte, NC
    693
    Quote Originally Posted by Edwin45 View Post
    Banditing,
    It might be "vuurvaste steen." Hopefully, you can toggle the below into your language...
    https://en.wikipedia.org/wiki/Fire_brick
    Aug 2015
    Arnhem/Netherlands
    109
    ewkearns,
    Ok thanks, but why firebrick?? (A lot of people recomend firebrick) but why.???
    I will ventilation under the spa, the dealer is recommended it.
    Do i get ventilation under the spa wit firebrick
    Factory is Caldera
    Above ground
    6 months old now.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Keep in mind that they make these free standing spas to sit on the ground/concrete pads. No need to hike them off the ground with space under it. It only gives rodents areas to congregate, build nests, and then destroy your spa.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Aug 2014
    Shallotte, NC
    693
    ewkearns,
    I'm going to give you a Scientific Wild Guess...... firebrick has low thermal conductivity... it could be thought of as a thermal insulator. However, ventilation sort of makes any effort at insulation a moot point.
    Aug 2015
    Arnhem/Netherlands
    109
    Ok Thanks guys, i don,t put m from THE grond.
    i make i kind of strip left right And front so THE water Cannot came to THE spa.
    Factory is Caldera
    Above ground
    6 months old now.
    Aug 2015
    Arnhem/Netherlands
    109
    I,m thinking to use this tiles 30x30 (and then completly full under the spa NO space between the tiles) then the spa is out the water.
    What do jou think?
    Then this (It only gives rodents areas to congregate, build nests, and then destroy your spa) wil not happend.
    Factory is Caldera
    Above ground
    6 months old now.
