Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Stains from dirt getting in pool
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    The previous owner planted turf to the edge of the coping, but he planted it too high. Runoff from the sprinklers went into the pool. There are now brownish stains in two corners of the pool floor where dirt-laden water entered. The stains are about 3 feet wide by 6 feet long.
    I am assuming these are mineral stains. What is the best way to remove the stains? As a test, I scraped a very small area of the stain with a smooth rock and it cleaned it up. Is this something that can be done with a "pool eraser" on the end of a telescoping pool? My pool chemistry is usually pretty solid. Occasionally my FC gets a bit high in the winter when outside temperatures drop but I get it under control quickly. TFP members have been very helpful with all my questions in the past, so thanks in advance!
    Pool Size: 9,000 gallons
    Pool Type: In ground, plaster
    Filter: Pentair 4000 Series D.E. Filter
    Pump: 1 HP Pentair Whisperflo WFE-4
    Heater: Sta-Rite Max-E-Therm 200
    Salt System: ECO-matic ESC 36
    Pool Cover: CoverStar, motorized cover
    Apr 2013
    Sacramento, CA
    2,769
    Re: Stains from dirt getting in pool
    Are you sure it's not just dirt?
    What color is the stain? Dirt usually doesn't stain.
    Hold a triclor puck against the stain for a few minutes if it goes away it's organic. Hold an aspirin against it. Does that work its iron.
    I would not be scraping.
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    I am assuming it is dirt since the stain pattern matches the pattern of the intrusion of dirty water. I will try the triclor and aspirin to test what the stain is. Thanks. Any other thoughts are appreciated.
    30,410
    Identify the stain as organic or inorganic.
    organic - get a tri-chlor puck and hold it in contact with the stain for perhaps five minutes......if the stain is gone, it is organic.
    Inorganic - crush vitamin C tablets (not aspirin) into pieces and put in a sock. hold the sock down onto the stain for five minutes or more. If the stain is gone, it is inorganic.
    Post back with the results and we'll discuss how to get rid of it.
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    Thanks Dave S. I will try the tri-chlor puck and vitamin C and post back. Thanks again.
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    Is there a place I can order less than $30 of tri-chlor pucks? My local supply places only have 5 gallon buckets for $30 or 10 gallon for $63. Or am I being too cheap
    Oct 2015
    Katy/Texas
    411
    Perhaps one of your neighbors has a pool that uses the pucks. They might give you one.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Dec 2015
    Chino/CA
    203
    What part of LA are you in?
    Chris B.
    New house w/ 28 y/o I.G. 15k gal. pool/spa, Plaster, Hayward DE-480S Micro Clear Filter, Pentair Whisperflo wfe-4, 1HP (Main Pump), Hayward SP2815x20 (Pump for spa jets), Versa Pool Heater, Hayward Pool Vac Ultra, TF-100 Kit
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    I'm in Culver City. I don't know any neighbors with a pool or I would ask them.
    Dec 2015
    Chino/CA
    203
    Oh ok! I live in Chino but work in Downey, if you're willing to take a drive I'd be more than happy to toss ya a couple pucks! LoL
    Chris B.
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    Chris B.,
    Thanks so much for the offer. I'd love to take you up on it but I am absolutely slammed at work right now, so Downey is a bit far for me. The $30 for pucks here in Culver City might be cheaper than the gas to Downey. Once I'm done testing, I'll let you know and maybe you could come and get the extra pucks!
    Dec 2015
    Chino/CA
    203
    For sure man!
    HAHAHAHA!!!! Thanks for the offer, but I have a full bucket of em'!!!!
    Chris B.
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    I think you can pick up a 2 pack at lowes.
    -Jimbo- My pool was full of dirt and trees. Now it's full of water and children!
    20k gallon inground pool, 18" raised spa 7' round, 8 jets, 3" spa plumbing. Pentair intelliflo 3hp vsp, Easy touch 4 w/ ic 40, CCP 420 cartridge filter, Raypak 407a w/ cupro nickel, Screen logic 2, Pentair intelliph, spa side remote, Pentair 5g color lights pool and spa, TF-100 test kit with speed stir and Dolphin Oasis Z5
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    Okay... long delay there. I finally got around to buying a tri-chlor puck from Lowe's. It did lighten the stain but only after it was left there overnight. Should I continue to the vitamin C test or is it conclusive with the tri-chlor? Thanks.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Trichlor is conclusive. Keep your FC elevated up near shock level for your CYA and brush often? Hopefully a couple of weeks will clear it up. Chlorine CYA Chart
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    Quote Originally Posted by pooldv View Post
    Okay. Will do. Thanks.
    If elevating the chlorine levels doesn't work (it's pretty stubborn staining), is there any issue with using a hard bristle wood block scrub brush? Something non ferrous.
    DFW, TX
    24,468
    That is fine, they also make stainless steel pool brushes.
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    Thank you. That's exactly what I need. That will take the stain off in a jiffy. I woke up this morning and thought, "aluminum". Glad to know they do them in stainless. I appreciate your help.
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    Quick update and request for advice here... I used the stainless steel brush with no luck. The stain is just too stubborn. Someone recommended putting down a layer of chlorine granules on the effected areas and letting it sit for a while to remove the stain. I did notice that wherever I had put the chlorine pucks, the stain was noticeably reduced over time. Any thoughts?
  20. Back To Top    #20
    DFW, TX
    24,468
    That means it is an organic stain. Raise your FC to shock level for your CYA or a little lower and brush daily. That should help reduce/remove the stains. FC/CYA Chart
