Results 1 to 13 of 13
Thread: What is the best way to plug inlet/ outlet lines for winter?
    Nov 2015
    Oxford CT
    48
    This is my second winter with pool and last winter I've used regular plastic plugs with tread and rubber O-ring.
    Is rubber plugs a better way to do it? If it is, which one is the best for 1 1/2 inch pipes?
    Thank you.
    Inground vinyl liner 20 by 40 pool in North East
    Hayward 1,5 HP super flow pump
    Sand Filter
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: What is the best way to plug inlet/ outlet lines for winter?
    If you mean the rubber plugs with the bolt that expands? I prefer the O rings but what you prefer will work
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Nov 2015
    Oxford CT
    48
    Quote Originally Posted by banditig View Post
    My O-ring plastic plugs doesn't fit that tight. I can see tiny bubbles at outlet port when blowing the other one. Do you think Teflon tape might help?
    Sand Filter
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Quote Originally Posted by psihiart View Post
    Yes, Teflon tape should help. Try not to over-tighten though, I had one that turned the eyeball fitting and wrinkled the liner, had to replace intire fitting.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,344
    The threaded kind do not work well with in ground pools. I would suggest the black plugs with the wing nut. Many members have experienced air leaks (small bubbles) over time. I do not know if Teflon tape would be the answer. I tried them and had to take them all out. If they are over tightened, this cause could damage. The black plugs have a nice tight seals and are very easy to remove.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    593
    Will the rubber plugs work if the inside of the pipe is threaded??
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Catanzaro's Avatar
    Jul 2014
    2,344
    Yes, they work great. You will see bubbles coming out until you tighten them up real well (then the bubbles will stop). This is when you know that the seal is pretty much 100%. Each year, I inspect the return jets underwater and never have I seen damage from the plugs.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    593
    Ok. Thanks!!
    Mark
    Catanzaro's Avatar
    Jul 2014
    2,344
    Kywildcats:
    One last item. When you open the pool, because the black plugs are on tight, it may be best to use large pliers. I carefully go down with goggles (you have to lay down on the patio) and apply a little pressure (counterclockwise 1/2 turn), and you should then be fine. You will understand once you turn as the "feel" is there. This is helpful so you do not snap the plastic. My steps (plugs) are inserted a bit inside. Each year, I have to use the pliers to pull out slowly. Next year, I will order larger black plugs.
    When the tight seal is broken and the air comes out, it is very easy to pull the rubber plug out. The threaded ones, in my opinion are dangerous if they are over tightened. Although, some people have success with them. I did not.
    Aug 2016
    HICKSVILLE, NY
    87
    For what it's worth, I've had one bad experience with using those rubber plugs on my returns. After one particularly harsh Winter, I opened in the Spring only to find one of the plugs lying under water on the pool floor. It seems that ice expansion can yank them out due to their conical geometry. Since then, I've only used threaded plastic caps with rubber O-rings to cap the returns. I spread a thin coating of silicon grease on the threads so I won't need a wrench to get them off when I open.
    28,000 gallons, 18x36, vinyl liner
    Hayward C4030 Cartridge Filter, Hayward TriStar VS 900 Pump, Raypak 400 BTU gas heater,
    Stenner 45mhp10 Peristaltic Pump (for bleach injection)
    2 skimmers, 2 returns, main drain, Lamotte ColorQ and TF-100 test kits
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    593
    All good info, thank you! I don't think I have to worry about ice getting that deep to grab the rubber inserts. I have three returns, and the pool company put it in 3 different kind of plugs. One Rubber, one screw in with O-ring, and one screw in without O-ring (it had A LOT of plumbers tape on it). I opened the pool this year, and I really never gave it much thought until I pulled them out of storage today. I am going to get three of the same kind tomorrow.
    Do you use more force than finger type on the rubber ones?
    Mark
    Catanzaro's Avatar
    Jul 2014
    2,344
    Tomolena:
    Information is always good to have. Personally, I do not lower my water more than 1" below the skimmer (only reason is to blow out the skimmers properly). One of the reasons is because of ice expansion. One year, I found that the ice for some strange reason was about 1" away from the liner. Somehow, the heat from behind the steal walls keeps everything in check. The solid cover I have (already in 2 weeks of closing the pool) is 6" above the closing level. By the time it becomes real cold and we have a deep freeze, probability is that another 6" of water will be sitting on the cover. The top layer of water only freezes at most about 1" (At least from the past 3 years of experience). I do not even believe the layer underneath the cover freezes at all, at least in NJ. The time it was frozen was because I kept pumping water off the cover, which now I do not until the spring.
    You make a valid point, and I do not feel comfortable lowering the water below the returns for this reason, including the integrity of the liner, pool walls, etc. (Even though the structure and how it was built is excellent). Personally, I see no reason to lower the water that much.
    I am assuming that no damage was done on the return line where the plug fell out.
    Best way to describe is that you keep on turning the wing nut until there are no more bubbles. Also, you have to place the plug flush with the threads or they will leak air.
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,536
    Put expansion plug wing nuts - in the "north south" position & they won't pop out..
