Results 1 to 7 of 7
Thread: Replaced pump and now small leak possibly the shaft seal.
    Jan 2011
    Richmond, Texas
    595
    Hi All -
    My main pool pump motor (p6ea6g-207l) went out on Christmas Eve. I was just able to replace the motor yesterday and thought all was good. I went out today and noticed a small amount of water under the pump. I dried it off and came back later and another small amount of water. Think quarter sized amount of water. I think it is the shaft seal that is leaking. I replaced the seal when I replaced the pump. Any suggestions on something I can do before I try to replace the seal again? Any pro tips on what to check/do if I have to replace the seal again? Also is it OK to run this until I get another shaft seal I ordered which should be here by Wed. Any help is much appreciated. Also this is the third pump motor I replaced and only one to leak so far.
    Thanks Philip
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Replaced pump and now small leak possibly the shaft seal.
    There are only a few things that will cause a new seal to leak:
    The seal was not installed in the correct direction
    The seal was not perfectly seated in the motor plate
    The seal surfaces were not perfectly clean when installed
    The seal was defective
    The first three are probably more common than the last one.
    Mark
    Dec 2014
    Riverside California
    482
    There is also a large O-ring between the seal plate and the pump body. You should replace this O-ring as it will become deformed after a while. You need to put a good deal of silcone on the O-ring and then as you tighten the clamp use a rubber mallet to tap the clamp as it is being tightened to seat it and get the best seal. Tighten the clamp by hand as much as you can but do not use any tools on it. You can purchase a "go-kit" for your pump that includes all seals and o-rings.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Good point, are you sure it was the seal that was leaking?
    Mark
    Jan 2011
    Richmond, Texas
    595
    Thanks for the replies. I did replace the gasket between seal plate and body. I pulled the pump out again this afternoon and found a suspect gasket that is in front of the impeller on a bolt like plastic screw. I could tell there was water intrusion on the shaft as there was a fine layer of rust. I cleaned both sides of the seal and replaced the gasket. I am running the pool now to see the results.
    Jan 2011
    Richmond, Texas
    595
    Update. The leak is now way smaller and from looking at it I only see about a dime size drop of water at any given time. However I can no longer tell if it is from the dry end or the wet end of the pump. Just feeling under the pump it seems it is now wet where the two sides meet and not perfectly under the pump. I will investigate more tomorrow when I have more daylight. This is very aggravating.
    Jan 2011
    Richmond, Texas
    595
    Hopefully last update. The pump was still leaking from the dry side when I got the new shaft seal in the mail today. I pulled the pump out again and replaced the seal. This time so far it looks like it is not leaking after over an hour of use. The only difference I know is that I used an OEM Pentair seal this time and some off brand from a pool store before. The OEM seal was much harder to put on the shaft of the impeller and looked better made IMHO. Fingers crossed that this resolves the leak.
