Results 1 to 19 of 19
Thread: Liquid Chlorine
    Dec 2015
    Sacramento California
    12
    Quick question, As I am about to assume service on my new pool, I have been checking out what the local pool supply has. They Sell HASA SANI-Clor in refillable containers. Is that just regular Chlorine like bleach but at 12.5%?
    Thanks
    Build Date 11/18/15 - 14K IG Gemstone (Pebble) pool, Hayward EcoStar Variable Speed Pump, 425sf SwimClear Cartridge Filter, Polaris 280 Pool Sweep with Booster Pump, Hayward Command 4 control system, GVA-24 Actuator, LED Light, Water Fall
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Re: Liquid Chlorine
    Probably. Chlorine, bleach, "shock", and "sani-chlor" are all just sodium hypochlorite. It's all the same thing just at different strengths in different shiny packages. Look at the active ingredient on the box/jug.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,539
    Re: Liquid Chlorine
    Look what I found! I bet this helps!
    http://www.poolwater.com/msds/vendor/Hasa/Sani-Clor.pdf
    Make sure there is high turn over as it can/will degrade over time in the sun. My place gets a new tank about twice a week during the summer.
    Kim
    Dec 2015
    12
    Re: Liquid Chlorine
    Thanks
    Nectarologist's Avatar
    Apr 2015
    New York
    428
    Re: Liquid Chlorine
    I like the concept of using refillable containers. I know store bleach can be cheaper but I got sick of the large, numerous containers. I wish a store by me did this. I don't mind the extra cost of pool store bleach b/c of the convenience and higher concentration.
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Liquid Chlorine
    Yes. The HASA stuff is just extra-strength bleach. It's what I use.
    Dec 2015
    12
    Re: Liquid Chlorine
    Just got a 4 pack!
    Jul 2012
    Tallahassee, FL
    30,539
    Re: Liquid Chlorine
    I hope you get a 6 pack for you! LOL
    Kim
    Aug 2014
    Northern IL
    4,615
    Re: Liquid Chlorine
    Ha! I can get 6-packs easily. Wish I could get HASA here in IL. I recycle my bleach containers with much guilt!
    Jul 2012
    Tallahassee, FL
    30,539
    Re: Liquid Chlorine
    That is another reason I was willing to get our new pool.......A Ace Hardware was built that is very easy for me to get to for my chlorine. I get four 2.5 gal refillable jugs at a time. Summer time they last me 12 days. Winter=lasting forever! LOL
    Kim
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Re: Liquid Chlorine
    I use those 4 packs of Hasa chlorine as well. That one of the 4 chemicals I buy from our pool store. Takes me about 8 days to use it all in the summer.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Apr 2015
    Katy, TX
    65
    Re: Liquid Chlorine
    Does anyone know if HASA services Houston?
    24K gallon, IG, plaster, Pentair Clean and Clear Plus Filter, Pentair Heater, Pentair Intelliflo pump, Built in March 2015, Taylor K-2006, Spa included
    Richard320's Avatar
    Jan 2010
    19,023
    Re: Liquid Chlorine
    Quote Originally Posted by Brian T View Post
    http://www.hasapool.com/m_hasa.php?ID=3190
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Re: Liquid Chlorine
    Brian, my pool store over here in League City stocks the 4 packs of HASA 12.5%, Glacier Pool Supplies. They also have another store around Spring.
    J.R.
    20K IG gunnite pool
    Cartridge filter
    Apr 2015
    Katy, TX
    65
    Re: Liquid Chlorine
    Quote Originally Posted by jrs_diesel View Post
    Can you pm me? I don't know if there are rules on the forum where we cannot discuss these kinds of things. Last thing I want is to get kicked off this forum!!!
    Last edited by kimkats; 01-12-2016 at 08:15 AM. Reason: took out email addy and put in pm
    Aug 2014
    Northern IL
    4,615
    Re: Liquid Chlorine
    Thanks.
    Jul 2012
    Tallahassee, FL
    30,539
    Re: Liquid Chlorine
    I took out your email addy and put in for him to pm you BUT you can talk about where you buy bleach/chlorine, etc on the board. It might be helpful for others in your area.
    Kim
    Apr 2015
    Katy, TX
    65
    Re: Liquid Chlorine
    Ok, thanks...I buy 10% liquid chlorine at Home Depot for about $4.75/gallon.
    By the way, if you get a Home Depot credit card, you will get 5% off of anything you buy there. All you have to do is use your credit card and remember to ask for the 5%; otherwise, they sometimes won't give you the discount. You will get the 5% discount right then and there.
    Jul 2012
    Tallahassee, FL
    30,539
    Re: Liquid Chlorine
    Make sure to check the date codes on Lowes and Home Depot as they do not always have a high turn over.
    We had one member buy enough chlorine for a SLAM. That is a LOT of chlorine..........when she added it and tested nothing happened! It was like she had not added anything to her pool. We had her check the date code............the chlorine was over 2 YEARS old! It had degraded so much that it was back to "water"! They gave her her money back. She went to Walmart and got the store brand 8.25% and got her pool clear.
    Kim
