Thread: Compool cp100 touch pad
    Jan 2016
    Rotonda West, Fl.
    2
    Hello all,
    New to this site and to pools. I have a question on the indoor touchpad, specifically what the adjustment screw located on the lower right side of panel. Could it be to calibrate temp sensor? If so, what is used for cross reference. THX.
    Dec 2014
    Riverside California
    482
    Re: Compool cp100 touch pad
    I would think that you should put an accurate thermometer in your pool, then use that reading to calibrate your temp sensor using the adjust screw.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Jan 2016
    Rotonda West, Fl.
    2
    That has been my thought too, but so far haven't found any concrete info as to if that is the correct step to follow....
