Results 1 to 8 of 8
Thread: mineral pool
    Dec 2015
    Arnold md.
    92
    mineral pool
    So I am a new pool onwer in the Annapolis Md. area, and was sold a mineral pool. We recently just built our pool and closed it in December, opened in October... have yet to use the mineral set up as we were just using chlorine since we were not really going to use the pool in November.
    I have seen many items about how bad mineral pools may be but my question is what good is in them? Is there anyone out there with a mineral pool that is happy with it?
    The PB seems to swear by them as long as your pool stays balanced but I don't know anything yet as I have yet to use it.
    Thanks
    Vinny B
    New Pool Owner Nov 2015
    20x40 mineral set up
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: mineral pool
    The bottom line is that the minerals, silver, zinc and copper in different systems, are practical only as an algaecide in pool use because of their extremely slow kill times on pathogens. That means that they will keep your water looking good, but they don't sanitize the water.
    Since a mineral system doesn't reduce or eliminate the need for a sanitizer such as chlorine, those systems are a supplement at best. But since chlorine does sanitize the water and control algae, the use of the mineral system gives little benefit. Add in the fact that metals in the mineral system can stain pool surfaces and swimmers' hair, there is really little good about them.
    JoyfulNoise's Avatar
    May 2015
    13,247
    Re: mineral pool
    Welcome
    Thanks for joining TFP and doing your research here. We do not advocate the use of mineral ion systems (copper and silver) as they are generally more expensive than just using chlorine (if you follow our methods), they have slow kill rates for most pathogens and the potential for damage to pool surfaces (scaling and staining) is too great.
    Use the search box at the top right corner of the homepage and search for terms like -
    "alternative sanitizers"
    "mineral systems"
    You will find lots of threads written in the topic.
    Typically speaking, for a new pool owner and a new pool, using chlorine will be your cheapest and easiest method of sanitation. Please read through the articles in Pool School to learn all about what it is we advocate here and ask as many questions as you like.
    Best wishes,
    Matt
    Matt
    Dec 2015
    Arnold md.
    92
    Re: mineral pool
    ok that makes sense...my auto chlorinator is also in the same spot as the Mineral cartridge area. Its a Nutri Fusion 2 system... we were sold on the idea that we were getting a salt pool and when the contract was written it said mineral, to me that meant salt... but guess what, I was wrong. At any rate the PB did say if we were not happy with it he would make it salt and eat the cost. So we will see how it works out this summer...thanks again.
    Vinny B
    Donldson's Avatar
    NW Ohio
    2,916
    Re: mineral pool
    If you can get the system replaced with a salt system at no additional cost I would jump on that right away. Mineral systems are a continuous cost, replacing the mineral cartridges as well as their overpriced trichlor dispensers. Using an SWG and following the TFPC methods is extremely cost effective and almost always leads to far better water quality than a mineral system.
    I offer this as a former Frog System user who is extremely happy with the difference in my water. I use manual chlorination with liquid chlorine rather than an SWG, but the results are the same: a significang increase in water clarity and significant decrease in upkeep time and cost.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: mineral pool
    As others have pointed out, if the PB will swap out the mineral system for a SWCG - go for it!! But, expect push back and a whole host of reasons why the "mineral" is better for you and your family. I have no proof, but I have a suspicion that some mineral manufacturers pay pool builders a spiff for installing them.
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    Re: mineral pool
    I'll vouch for the SWG system. I have one and it just could not be any easier to maintain a crystal clear pool.
    Divin Dave,
    Aug 2014
    Northern IL
    4,615
    Re: mineral pool
    Switch it out!!!! There is really no reason not to, especially if the PB said he would at not cost! I wouldn't wait to see, you are going to be putting unnecessary chemicals in your pool that will stay there for a long time and could cause issues don the road.
    Get yourself a good testkit too, btw!
