Thread: How to remove ClearO3
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    We just got control of our pool and I want to remove the ClearO3 unit completely. Not just turn it off.
    There is a black tube that connects into the pump that concerns me. Any ideas how to remove the tube and seal that port?
    Here is the ClearO3 in the background.
    Here is the connection to the Jandy VS pump.
    Thanks!
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    Re: How to remove ClearO3
    Hi bdrums,
    Pool pumps have drain plugs in the botom of them. I would imagine the drain plug was removed and that tube connected into the drain port.
    Here is a link to what they look like (for reference only).
    Amazon.com : Jandy R0446000 Drain Plug, O-Ring : Swimming Pool Pump Accessories : Patio, Lawn Garden
    Divin Dave,
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Ah. Ok. I'll look at it more closely when I get a chance. Thanks!
    Build thread
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    That tubing is more than likely the return line for a flow switch so the 03 doesn't run while there is no flow from the pump. As Dave mentioned, removing the tubing and replacing the drain plug will likely solve the issue.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Jan 2014
    Buckeye AZ
    807
    It's the tube that the ozone travels through, where it enters the pump basket. Ours is set so the main power to the unit only comes on when the pump is turned on, it's not activated by flow/noflow. I have the same O3, and I am also looking to take it out. Just need to buy the right drain plug for my hayward. And then, disconnect the power to it...
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
