Thread: Air bubbles
    Dec 2015
    Cypress, Texas
    57
    Air bubbles
    I have an spa attached to my pool. When I put the pool in spa mode without the air blower I get air bubbles coming out of the return jets, is this normal? I would think not as there should be no air in the lines with the air blower off.
    16,388 gallons, IG, Pebble Sheen, Pentair Clean & Clear Plus cartridge filter, Pentair Whisperflow Pump, August 2015, Taylor K-2006, spa
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Air bubbles
    I get the same thing, was told it was normal to have some of the Jets blowing air...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: Air bubbles
    In a correctly designed spa, there is no need for a blower because the jets use a Venturi to draw air from the air line through the jets and into the spa. Blowers are added to either boost the performance of the jets or to purge the airline of water in the event it makes its way into the pipe.
    It is perfectly normal to have air coming from the spa jets without the blower running.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Dec 2015
    Cypress, Texas
    57
    Re: Air bubbles
    Good to know, thnx
