Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Artificial Turf Near a SWG Pool?
    Nov 2015
    Woodland Hills, CA
    176
    Anybody have any experience or comments about installing artificial turf near (about one foot) a pool with a SWG? One comment is that the salt will damage the artificial turf, but I see football games played on the stuff and I have several neighbors that have had it in their front yards for over a year with no ill effects.
    Input appreciated.
    Thanks
    O/B Woodland Hills, CA : O/B12x30 inground with 6x6 10-jet spa, 10,500gal, 6' Baja deck, 42" spillway, All Jandy: 400k heater, 2.7 HP VS pump, 1.5HP booster spa pump, SWG, Intellelink controls, (4) LED lights, cartridge filter and BlueSquareQ360 infloor cleaning system, Eclipse drain, glass tiles, Zanzibar white pebble finish. Broke ground 2/18/2016, completed 8/16/2016. TFT 100 kit.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,428
    Re: Artificial Turf Near a SWG Pool?
    I love the idea. I would make sure to rinse the area where the kids get in and out after a day of fun because that is where a problem will happen IF it happens.
    Kim
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Have had mine that close for years with no issues whatsoever. (Have a SWG).
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    JoyfulNoise's Avatar
    May 2015
    13,179
    I don't have it close to the pool but in the back yard (~800 sq ft of it). My kids love to setup the sprinkler on it and run through it. Never have a problem with it except that it does get hotter than real grass. I have no dogs so that's not an issue.
    I love my turf, it looks very real and, best of all, no watering, weeding or trimming required!! I would recommend if you do install turf then get a good quality turf rake and be sure to move everything off of it a fluff the turf up monthly. Keeps it from getting matted down.
    Matt
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Per Joyfulnoise, matting down of the turf is often the number one complaint ppl have after they get their Turf installed and have traffic plied to it. My turf is decorative but even with that, I still have to rake it out where I walk to get to my planting bed.
    I've read about but have not yet found, a bristle/brush attachment that one can place on a higher cc gas powered weed wacker to make fluffing it back up easier and quicker. The pros use a heavy duty gas powered brush for this but it's way too pricey.
    Nov 2015
    Woodland Hills, CA
    176
    Thanks youse guys! No kids, so that won't be a problem.
    Jaimslaw - do you have some pictures by any chance? I've not seen any real life examples
    thanks in advance,
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Don't have any close ups but here are two pics taken just prior to my recent pool replaster.
    I believe the best look is achieved if you have your installer lay down 2"x2" bender board along the edges and then staple the turf to it. By doing so, you get the turf to sit higher up - ie. you see more of the edge of the turf blades as it lays up against the adjacent concrete (or whatever) surface. This keeps the turf from being too low, which can look like a pool table, where the top of the turf blade is practically level with the adjacent grade or concrete. By seeing as much of the turf blade edge as possible, it will look more realistic. Not many installers use or even know of this technique.
    Also, getting the highest priced turf with the highest blade height, density and weight is not necessarily the most desired look IMO. The denser stuff will often give too much of a carpet / groomed look (ie., too perfect looking). I also found it more realistic if I stayed away from the deep green color. Just doesn't seem to look natural.
    Jul 2012
    Tallahassee, FL
    30,428
    That is SO nice looking! I like how it is even with the patio. Nice touch!
    Kim
    Nov 2015
    Woodland Hills, CA
    176
    I can't thank you enough!
    That is a great tip about the bender board!!! I assume that the top edge of the bender board is flush with the top of the coping or other adjacent surface? So I understand - is the turf rolled over the edge of the bender board and stapled in place (kind of like screening a window) and then installed into the ground? I think my difference might be that we will not have any paved areas around the pool other than (possibly) some stepping stones & coping, but I get the idea and it is good to see the turf close to the pool.
    I know what you mean about the turf quality. The most impressive turf I've seen was at a relatives house in Fresno. The turf actually had a little bits of brown that emulated the dead clippings you would get when cutting the grass.
    On another note - what is your pool finish? We are looking for turquoise water and yours looks that way in the pictures...looks great.
    thanks again!!
    May 2015
    13,179
    Quote Originally Posted by Frank Rizzo View Post
    This is like my turf. It has some yellows and brown in it. Also, any high quality turf has UV and oxidation blockers built into the fibers, not applied as a spray.
    Matt
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    That turf is beautiful!
    Is turf usually applied over a compacted dirt surface, sand or concrete?
    What's a ballpark price for turf?
    I can't get over how pretty that looks! Does it hold up to snow and ice?
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    May 2015
    13,179
    Quote Originally Posted by Nursenini View Post
    Turf is typically applied over a layer of compacted soil with a top layer of DG (decomposed granite). So typically you dig down about 2-3" and then do your compacting and DG spread. That's how it was done for me. DG allows for good drainage.
    My turf cost $8/sq ft, that included materials and installation. If they have to do a lot of surface prep, that can add to the cost.
    My turf has not had huge amounts of snow on it (I live in the desert but we can sometimes get flurries) but it's held up fine. Typical quoted lifetime of turf is 8-10years depending on traffic.
    Matt
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Perfect! Thanks for the info, Matt!
    Denise-TFP Guide
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Correct, though most installers will set the bender board a little below grade and about 1/4" away from the adjacent hardscape; and they'll wrap the turf over the bender board and tuck it into the 1/4" gap. I preferred to just have the bender board sit a hair below grade so as to get the height of the turf up as much as possible, as can be seen in this close up:
    Bender Board is placed first (staggered wood stakes are hammered into the ground - bender board is then screwed into the stakes to anchor the bender board in place).
    The pool finish in the prior turf photos was the old worn grey plaster finish. I replastered this summer with a modified Stonescape Mini Peeble in Tropics Blue):
    Nov 2015
    Woodland Hills, CA
    176
    Thanks much.
    this is a great help and I appreciate you taking the time!!
    Jan 2015
    Austin, TX
    1,095
    Wow I wish I could do my entire yard in that stuff. I am guessing it would be 70k or so haha. Plus I would have to do it every 7 to 10 years. Blah...
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    Aug 2014
    Houston tx
    2,524
    Ummm, maybe you could talk your PB into throwing it in... j/k
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Aug 2015
    Potomac, MD
    92
    I'm interested in putting in Artificial turf. Who do I talk to get estimates? Pool specialists, landscapers, or turf manufacturers?
    Outdoor concrete pool, 14,000 gallons, Purex Triton Clean & Clear Plus cartridge filter.
    May 2015
    13,179
    Quote Originally Posted by Grayson73 View Post
    Landscapers or landscape architects if you want good turf. Figure it costs about $6-$8 per sq-ft installed.
    Matt
  20. Back To Top    #20
    Jan 2014
    Buckeye AZ
    807
    we just went to the home show and felt everything from every turf vendor. reconfirmed what we already liked from last year's show. It's a thinner blade, no reinforcing spine. American made 15 year warranty, also about $8 sgft. But it's soooo soft. all we have is a small dog and not a lot of traffic.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
