Thread: Valve problem
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    Valve problem
    Turned to spa mode last night and found the spa drained. Put into service mode this morning and turned pool on to fill spa then put in spa mode to check on Jandy valve rotation and sure enough the spa side turned correctly, but other 3 way "chattered" but would not turn. Is Jandy shot or is there something else causing this? I've included a pic of my setup. Thanks for any thoughts on this.
    32 x 15 15500 gal. IG gunite, 6 ft. round attached spa, diamond brite 2 plaster, flagstone coping w/concrete spray deck, IntelliChlor IC-40 SWG, 2 hp Max-E-Pro pump, 450 sq.ft. System 3 cartridge filter, 400k Max-E-Therm NG heater, automation is IntelliTouch i7+3, Polaris 280 pressure side cleaner,
    TS 100, Borax
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Valve problem
    Maybe you can rebuild the valve instead of replacing it. From other threads I've read hear about spas draining to pool level is problem with check valve.
    Parts for Jandy Valve 3 Port Jandy 1154,3344,2875,2877 Valve 3 Port Valves, Swimming Pool Valve Parts
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Valve problem
    If the automated valve is making a clicking sound then it has broken and needs to be replaced. Once you remove the automated control from the valve body, you can use a handle to confirm the valve itself is working correctly. BTW, this is a very common issue with these automated valves controls, they break from time to time.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Valve problem
    I would check the actuator first, use the toggle switch on back of valve to see if it moves the valve..
    The system doesn't have to be on to test it..
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Valve problem
    If it chatters or clicks remove the actuator, remove the handle from the actuator, and put it on the valve (you'll see), and try rotating the valve by hand. If you can rotate it freely from pool to spa as the actuator does, replace the actuator. If you can't, take the valve apart and find out what is jammed in there and remove.
    Factory Warranty Station for:
