Results 1 to 8 of 8
Thread: am I doing something wrong?
    Aug 2008
    Las Vegas, NV
    116
    On the surface of my pool, there is a lot of tiny, tiny grayish whiteish "particles". I guess this is plant matter from the stuff blooming out right now. I can skim the surface of the pool over and over and over, but this stuff slips right though the skimmer. Is there anything I can to to clear the surface better? Where there is plenty of movement, the surface is clear, but this stuff is pretty heavily concentrated over in one corner of the shallow in of the pool.
    TIA
    Pam
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: am I doing something wrong?
    People use what's called "skimmer socks" you can buy them at pool stores I think. I've never used one. But I also think I read on here about people using old pantyhose somehow? Hopefully someone will chime in.
    The alternative to skimmer socks is knee high stockings. Either one can be put over the skimmer basket to help trap pollen. But I don't think that is the problem here.
    In the spring, when there is lots of pollen in the air, there is always going to be something on the surface of the pool. If everything is working correctly, the skimmer should catch a lot of it, at least when the pump is running. But there will nearly always be some pollen still floating on the surface of the pool.
    One possible explanation is that there is just lots and lots of pollen right at the moment, and the skimmer can't keep up (or the pump wasn't running when you looked).
    The other possibility, is that your circulation isn't very good and surface debris is not getting pushed into the skimmer(s). When everything is working right the water should flow around the pool in a circle and slowly bring most of the surface debris to a skimmer. High winds can disrupt this process somewhat, but even then you should see water moving around and past the skimmer(s).
    If the water is not circulating correctly, you can adjust the aim of the return jets to help push the water around in a circle (or sometimes more complex patterns for oddly shaped pools).
    Feb 2008
    Denton, TX
    5,061
    Yep...you need some skimmer socks. They can be found at the bigger Wal-Marts and all pool stores have them. They come 3 or 4 to a pack and will run you about $6 or $7 per pack. I use them year round and you would be surprised how much garbage they trap. I have also noticed that I can go much longer between filter cleanings with them installed.
    They simply strecth over the filter basket and catch what normally would go right through. I have heard of people trying pantyhose with mixed results (on the filter basket, that is ). I think that the skimmer socks are much tougher and last a little longer.
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    I have been using panty hose over my skimmer basket for the past swim season and just put one on when I started up my pool this past weekend. catches all kind of garbage. i had problems with very fine "sandy type" granules on the bottom, but the pantyhose does the trick.
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by 257WbyMag
    Couldn't agree more!
    You're done SLAMing when:
    Apr 2009
    Orange Park, FL
    104
    Yup, I've been using my old knee high stockings for years. They trap the very smallest of particles. I do a daily rotation using 2 knee highs. Each day I remove the dirty knee high and replace with the clean one. The dirty one gets rinsed with a hose and hung to dry - ready for use the next day. Simple and cheap since I have an abundance of old knee highs. I also use them to tie my plants against stakes, tie storage boxes, etc. They come in handy. Sorry, to ramble - will shut up now!
    15x30 IG vinyl liner pool, pool cage
    Hayward S-220T high rate sand filter and Hayward super pump w/1hp motor
    Hayward SwimPure Plus SWG
    Polaris 380 cleaner and booster pump
    30,421
    I'm gonna post a slightly different take. It seems to me that Mom is talking about pollen or something on the surface of the pool that she is unable to remove manually......not that they are passing thru the permanent skimmer.
    I may be misinterpereting OP's thinking but I think she was asking how to get the stuff off the surface of the pool.
    If that's the case, the answer is not good. This time of year trees are throwing everything they can think of into your pool. From pine pollen to seeds to flowers, etc. About all you can do is be patient and keep scooping the surface. The permanent skimmers will eventually take in most of it but you have to run the pump 24/7 and still skim manually.
