Thread: Pool Cover Pump
    Pool Cover Pump
    Hi to all:
    Happy New Year!!
    I have a WAYNE WAPC250 1/4 HP Automatic ON/OFF Water Removal Pool Cover Pump which indicates that you can leave the pump on the cover during the winter. There always an inch or so of water on the cover in a low spot where the pump is placed. I have found that if there is some debris in that area the pump keeps going on and off. The hose is frozen so water can't be removed from the cover anyway and the water in that area will freeze soon I be away for an extended period so I will pull the pump and store it until spring.
    Anyone experienced this issue? Suggestions?
    Thank you,
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    Aug 2014
    Northern IL
    4,615
    Re: Pool Cover Pump
    I'm not sure if it's debris, or if the water just has nowhere to go with your frozen hose.
    We either switch out hoses or just bring one inside to thaw. If you do bring the pump inside, store it where it's handy. You may need it periodically if you get any warm spells where you live.
    Re: Pool Cover Pump
    Many thanks, yes it probably just needed cleaning which I did this a.m. Seems to be working fine.
    Best Regards,
    Gary R.
    Aug 2014
    Northern IL
    4,615
    Re: Pool Cover Pump
    Was it debris or just a frozen hose?
    Re: Pool Cover Pump
    There wasn't much debris, just a little around the sensors so maybe it was just the fact that the hose was frozen. Also, could have been the freeze sensors coming on. I was under the impression that one could leave the pump out all winter but the manual clearly states it should be brought inside.
    Thank you!!!
    Gary R.
