Results 1 to 7 of 7
Thread: CH importance in a spa ?
    Nov 2015
    VT
    85
    I just refilled my tub and I used softened water this time because I wanted to try having some salt in my water and I figured that was the easiest way. I guess I could have crushed up softener salt and added that to the spa instead.
    The softener removes most of the calcium from the water.
    I understand that some pools need calcium in the water to prevent it from taking it from the pool shell.
    Do I need calcium in my spa water even though the spa has a plastic shell?
    Hot Springs Sovereign (1999?)
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: CH importance in a spa ?
    Some folks get a bit of foaming in their water and some calcium added helps that.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    CH between 100 and 150 is good. More here, How do I use Chlorine in my Spa (or pool)?
    Nov 2015
    VT
    85
    I assumed I had zero CH and I added 7.5 oz. of (old) Balance Pak 300 to my 350 gal.
    I added 5 drops of (HTH) indicator to a sample and it's supposed to turn the water red if there's any hardness. It doesn't.
    Do you think the indicator is at fault or the Balance Pak 300 or...?
    DFW, TX
    24,502
    It is probably the test. Adding 7.5 oz of calcium chloride or calcium chloride dihydrate will add 109 ppm to 350 gallons. Even if it is old it should not degrade. Should be good to go on CH.
    Nov 2015
    VT
    85
    Quote Originally Posted by pooldv View Post
    Thanks. I do have a Taylor kit on the way. Hopefully I can sort it out with that.
    DFW, TX
    24,502
    Good plan!
