Results 1 to 8 of 8
Thread: My home made solar collector
    East_Akl_Neil's Avatar
    Apr 2012
    Auckland, New Zealand
    70
    Hi All.
    Just thought I would share a couple of pix of my Solar collector that I have just finished building in the past few days as part of the plumbing upgrade that I have been working on. In the pic that shows it installed, it would seen that the collectors are hidden, but that is just the angle that the photo is taken on.
    In 2 days it has raised the pool 7C, from 23 to 30. Bit more of a success than I thought it was going to be.
    After I finished Assembly, but before installed on the Roof.
    Once installed on the roof.
    The pool that it is heating.
    Its a pity that the next few days are going to be raining, but will be interesting to see how much the temp goes down in that time anyway.
    Neil
    Late 1970's 39000L IG Concrete Pool with Vinyl Liner
    Austral FT55 Sand filter
    Hurlcon E170 Pump Brochure,Manual
    32-40mm Pipe work
    Living in beautiful New Zealand
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Re: My home made solar collector
    You KNOW you have to give details! What is it made of? I see the white PVC pipe but am not sure what the black things are-hoses?
    That is so neat!
    Kim
    Apr 2012
    70
    Your right the white pipe is 50mm PVC. The black pipe is just 13mm Irrigation tube, and lots of time. I've not got any assembly pictures, I dont normally remember to take photos at the right times. (Too busy in what I am normally doing at the time.) I'll go and get a close up of the interface at some point, but its raining at the moment, and the pool is filling nicely from the rain.
    32-40mm Pipe work
    Apr 2013
    Sacramento, CA
    2,769
    That is about 12 degrees Fahrenheit. Frankly I'm surprised. Was that one day?
    Nectarologist's Avatar
    Apr 2015
    New York
    428
    That's great!
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    Apr 2012
    70
    Quote Originally Posted by gwegan View Post
    That was over 2 days. All the heat has gone now due to the rain, but come Monday should be nice and fine again
    32-40mm Pipe work
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    Hi from the 'naki. Would love to see pics of how you did the connections
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,250
    Yeh, I'd like to see the connections too and well done. Will you be painting the PVC pipe?
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
