Thread: Saturation Index (sci) Question
    Sep 2015
    Scottsdale Arizona
    1
    Does it matter if csi is -.5 or -.2 or 0.0 with a high CH of 550ppm I think it is better with a slight negative value to keep calcium from forming on pool surfaces, true or false? Pool math
    States -.6 to +.6 is satisfactory.
    TF-1000 test kit. Using Liq. Chlorine and pool math.
    FC 12
    TC 12
    CC 0
    TA. 80
    CYA 80 to 90
    PH 7.5
    CH 550
    Water temp 48F
    15,000 gal in ground pebble tech pool
    Triton 100HD 4.91sq. ft. filter area sand filter
    Challenger High flow 2HP pump/motor
    JoyfulNoise's Avatar
    May 2015
    13,201
    Re: Saturation Index (sci) Question
    It is preferable to keep your CSI between -0.3 and +0.3. Outside those limits there is the potential for corrosion or scale but no one can easily predict the rates.
    Looking at your numbers, your pH is really too low for a winter pool. Why are you keeping it at 7.5? In the winter, you can easily allow your pH to drift up to 7.8 and it will probably stay there for quite a while. Right now, with a pH of 7.5, your CSI is -0.32. If you let it rise to 7.8, your CSI would be -0.04. You'll have fewer acid additions if you let your pH rise a little higher.
    Matt
