Results 1 to 8 of 8
Thread: Leak under sand filter (video included)
    PB replaced the sand in my filter yesterday when he opened the pool.. I noticed today I lost a few inches of water overnight and a have a steady leak coming from under the filter base. Any idea where it might be leaking from?
    http://www.youtube.com/watch?v=-llTIV6nN38
    2003 Marquis Euphoria - 400gal
    Re: Leak under sand filter (video included)
    Since they just replaced the sand, it is probably coming from the filter drain plug. If a simple tightening of the drain plug doesn't fix it, call back who ever replaced the sand and get them to fix whatever they did wrong.
    Thanks.. the drain plug is in the rear and doesn't not appear to be leaking.. regardless, I called him and asked him to come back out.. I am irratated to say the least.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I should think so...that was a heck of alot of water
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Wow, that is a lot of water. I've seen filters crack around the 'belly button' on the bottom where the mold is cut off, but only on fiberglass tanks. The tank can also crack around the base if it's manhandled too much. I had some guys do that after they refilled a 15 year old filter only to discover they had moved it in the process and it didn't line up with the plumbing anymore. So what did they do? "You get on one side, I'll get on the other..."
    There's no reason that should be the case with your filter since the whole top comes off and the MPV stays connected, but the water's coming from somewhere. If you don't see it trickling the tank anywhere then there's probably a crack.
    PB is coming back out tomorrow. I have the MPV on recirculate for now.
    The filter drain tube located on the underside of the filter was cracked. PB said the sand replacement had nothing to do with the cracked tube as the only way to get to the tube is to lift the entire filter off the ground. I suppose there is a possibility that someone may have stepped on the end of the tube from the time it was closed last fall. In any event, he replaced the tube and all is well. No charge either!
    11,969
    Quote Originally Posted by jjdurrant
    No charge either!
    Excellent!
