Thread: Raypak RP2100 Solar Heater
    Dec 2015
    Kissimmee
    3
    Hi, I just moved into a rental home that said it has a solar pool heater. The sticker on the unit is faded but I did see that it is the raypak rp2100 millivolt. After searching online, it l see that this is a natural gas heater ? Are they often reconfigured for solar? There are solar panels on the roof? Any insight would be appreciated.
    Thanks !
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Raypak RP2100 Solar Heater
    It's not solar, it's gas.
    Millivolt is the ignitor.
    Are there panels on the roof? Could have both!
    Dolphin E10 Cleaning Robot.
    Dec 2015
    Kissimmee
    3
    Yes, there are panels on the roof. I do not have a manual and the landlord is useless. How does it work?
    Dec 2015
    Kissimmee
    3
    any chance someone can direct me to a download of the manual for using solar instead of propane, is that even possible?
    banditig's Avatar
    Sep 2015
    Ohio
    466
    The solar is to basically pre-heat the water before it goes to the heater, if they set it up correctly. Thete are a coup different manufacturers of solar heat panels, I had Fafco.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
