When you're going from a high TA to a lower level, then you shoot for a 7.2 ph. As you close in on the optimal TA, then you begin to choose a higher ph target. Since you're getting close to a good TA, I would suggest lowering the ph to about 7.7 as needed.
With tabs, your ph should not rise too much because the tabs are acidic. Also, monitor your CYA to make sure that it does not get too high.
