Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: can muriatic acid and baking soda be added to pool at the same time?
    Dec 2015
    arlington, tx
    100
    my pool guy wants to do this tomorrow if pH is too high and alkalinity is below 80. i've never done this- always wait 24 hours. is this ok?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,733
    Re: can muriatic acid and baking soda be added to pool at the same time?
    That is a little counter productive. Do you do your own testing? Can you post a full set of numbers?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    If the pH is constantly going too high, then you don't want to raise the TA.
    Is this a salt pool?
    Support the site
    30,402
    Always remember.......
    pH up - 20 mule team borax (TA comes up to)
    pH down - Muriatic acid
    TA up - Baking soda (pH doesn't come up much)
    TA down - aeration and acid...it's process found in Pool School that you must read to make TA change quickly and permanently.
    It sounds like your guy has them a little mixed up.
    Dec 2015
    arlington, tx
    100
    Quote Originally Posted by bdavis466 View Post
    on 12/12 FC 6.6 pH >8 alk 110, I put in 7 c acid
    on 12/14 FC 5.0 pH 7.7 alk 90, I put in 5 c acid
    on 12/17 FC 4.5 pH 7.7 alk 80, I put in 7 c acid
    on 12/19 FC 4.5 pH 7.7 alk 70, I put in baking soda (forgot to document amount)
    on 12/20 FC 4.0 pH >8 alk 110, I put in 2.5 c acid
    on 12/24 FC 3.5 pH 7.9 alk 100, pool guy put in 4 c acid
    on 12/26 FC 4.0 pH 7.4 alk 90, nothing put in
    on 12/29 FC 3.5 pH >8 alk 80, I put in 4.5 c acid
    Jan 2012
    'burbs of Augusta, Georgia
    7,256
    You don't report your TA level...that plays in to your pH rise also.
    Did you know that your bubblers and fountain will increase your pH from the aeration they produce.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,733
    On 12/19, you added baking soda because the TA was 70? Why?
    I would consider a TA around 60 ideal. Raising the TA is only going to make your pH rise faster and higher due to carbon dioxide outgassing. With a TA of 60 and a pH of 7.6-7.8, your acid additions will be much further apart. Unless you are using an acidic form of chlorine (tricolor) or have very low TA fill water, there is no need to ever add baking soda.
    Also your FC level is more than likely below the minimum threshold for your CYA level.
    -Brian-
    POOL BUILD
    Dec 2015
    arlington, tx
    100
    i thought TA should be 80-120.
    currently water features aren't on
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,733
    80-120 is a guideline. I'd leave the TA alone and see where it settles in
    -Brian-
    POOL BUILD
    The 80 to 120 rule is based on incorrect information. It is not a useful guideline to follow. I would suggest that you base the TA on how the ph moves. If the ph rises, the TA is probably too high. If the ph drops, the TA is probably too low. When the ph remains stable, the TA is just right.
    Support the site
    Aug 2014
    Shallotte, NC
    693
    At a TA of 50, my war with pH was over. I never have to adjust water balance for any reason, other than heavy rains. However, we have to acknowledge that your pool is Pebble and that may require a bit more juggling, while you monitor the CSI.
    Oct 2015
    Katy/Texas
    411
    Quote Originally Posted by JamesW View Post
    Is the 80-120 TA rule on this site? If it is, and if it is not valid, I would like to suggest that that reference be revised. It's difficult enough to understand pool chemistry as it is.
    Just my $0.02
    Just saw in "The ABC's of pool chemistry" TA recommended level (60-120).
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,733
    It was changed a couple months back for that very reason, but I think there are still some areas that say 80-120.
    My understanding was the higher range was more intended for those that use trichlor to prevent the pH from crashing; odd since pucks are so heavily discouraged. At any rate, a TA of 60 will significantly help with acid additions regardless of the method of chlorination.
    If trichlor is used, one must monitor the pH and TA to make sure that they don't get too low. With LC and SWGs the natural tendancy is for the pH and TA to rise anyway so its not much of an issue(even with a TA as low as 50).
    -Brian-
    POOL BUILD
    The recommended levels are shown here.
    Support the site
    JoyfulNoise's Avatar
    May 2015
    13,173
    Marcion333,
    Your pool and plaster are new, so you will likely have fast rising pH for a quite a long time to come (12 months or more). You're going to need to find a pH and TA that works best for your pool as a new pool surface tends to behave a little differently from an older, seasoned pool. TFP Recommended levels are a good starting point but it will require a little experimentation on your part to find out what works.
    You can not mix what we teach here with pool store or pool service advice. The two are incompatible with TFP and you are just going to get all turned around trying to figure out why TFP says one thing but the pool service guy is doing another. I know you're concerned about taking over pool care on your own as it seems like a daunting task especially if you've never had to deal with a pool previously. But, if you get the recommended test kit and you follow what we teach here, I can assure you that you will not need a pool service (and save that money being spent). The choice is yours and I wish you the best of luck with your new pool.
    Regards,
    Matt
    Matt
    Dec 2015
    arlington, tx
    100
    the recommended TA level at this site using bleach with plaster is minimum of 70.
    what is the recommended TA level using trichlor with plaster?
    I find that using the ph as a guide works better than a predetermined TA target. I would suggest that the ph be kept at 7.8 and the TA adjusted as needed to keep the ph there.
    Support the site
    Dec 2015
    arlington, tx
    100
    today 12/31 FC is 3.5, pH is >8, and TA is 80. i put 2.5 cups acid in (chart says this will lower pH to 7.7).
    i like the idea of using Ph as a guide. i will let TA fall below 80 and see what pH does.
    Dec 2015
    arlington, tx
    100
    PoolMath says, "To lower TA you reduce pH to 7.0-7.2 with acid and then aerate to increase pH."
    does this mean i should put more than 2.5 cups acid into pool?
  20. Back To Top    #20
    Dec 2015
    arlington, tx
    100
    i went ahead and put an additional 5 cups acid into pool today for a total 7.5 cups. we'll see what pH and TA are tomorrow.
