Thread: Identify this solar heating gadget. [pic]
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    I've received a flyer from a local pool store with an advertisement for the "latest innovation in solar heating". While I doubt this is any better than regular solar panels, I'm curious as how it is supposed to work. I've googled "Solar Coil" but haven't found anything relevent.
    Anybody knows what it is ?
    14X24 ig vinyl pool 3ft-4 1/2ft deep - 7000 gal
    Aqua Genie skimmer and return - no main drain, 1 hp hayward pump, 27" Hayward filter with Zeobrite,
    Aqua Logic P4 controller + SWG, 2 lights
    192 square feet of solar panels controlled by P4, 5KW electric heater (just in case...)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Identify this solar heating gadget. [pic]
    That looks similar to the product described in this thread
    It is basically a very small, dramatically over priced, solar heat panel.
    The amount of solar heat you get depends on the total size of the panel. This panel is about 4 square feet. Compare that to a standard panel at 80 square feet, which costs about the same. Normally, you need over one hundred square feet to get a significant effect, and many people have several hundred square feet of panel.
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    Yep, it appears to be the same laws-of-physics-defying thing as discussed in the other thread.
    I don't know what material the clear "bubble" is made of but I'll make a guess that it's some sort of cheap plastic and that in after a summer or 2 in the sun it's going to be yellow and opaque...
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by el_steak
    Not to mention you can get them for about $70 less at Sam's.
