Thread: Pump and filters size
    Dec 2015
    Chino/CA
    5
    Question Pump and filters size
    Good evening, Like I said on my first post, I just bought a home with a pool. I would like to know if the equipment on my pool are the correct size (Adequate) for the the pool.
    Here is the information
    Filter: D.E. Filter Model: SMBW2060
    Pump: Pentair 1/2 HP, 1.90 SF, .98 SFHP, other information on pump: P/N 011511, PMP WFE-2 115/208-230V
    Voltage: 230
    Poll capacity (Gallons): Depending on which calculator you use, the total gallons is between 19,000 and 20,000
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,387
    Re: Pump and filters size
    HI! Look what I found! Here is the manual for your filter. It looks like it is big enough.
    https://www.inyopools.com/manuals/33...lters_2000.pdf
    I do worry about the pump a little 1/2 hp is not much> I was not able to pinpoint your pump. Do you have a model number or something else that will make search easier? Is it 2 speed?
    Kim
