Results 1 to 8 of 8
Thread: Pool School
    Dec 2015
    Sacramento California
    12
    Pool School
    Hello Everyone, first post here. Before I start my myriad of questions.....=-).....If there a PDF version of pool school that can be printed out? Additionally are there any good record keeping apps and calculators for iOS devices?
    Thanks!
    J
    Build Date 11/18/15 - 14K IG Gemstone (Pebble) pool, Hayward EcoStar Variable Speed Pump, 425sf SwimClear Cartridge Filter, Polaris 280 Pool Sweep with Booster Pump, Hayward Command 4 control system, GVA-24 Actuator, LED Light, Water Fall
    Jul 2015
    Central Valley CA
    1,109
    Re: Pool School
    Welcome! A PDF is a good idea but I don't think it exists might be an idea for the suggestion box. Pool School links are well laid out and not hard to get through. almost all of what you will learn here around water chemistry requires reliable testing most have a kit form tftestkits.net, in Pool School there is a comparison chart of the recommended kits. As for apps I tried a few and found them all lacking, finally settled on a note book and bringing up PoolMath in a browser on my phone.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    JoyfulNoise's Avatar
    May 2015
    13,231
    Re: Pool School
    You can just print out information as needed, there is no PDF document of all the info. Many folks like to print out the FC/CYA chart and Recommended Levels tables and paste them into a notebook...which brings me to the second question.....
    Honestly, there is no one great iOS or Android app out there. There are quite a few but they all suffer from one defect or another - no history logging, wrong chemical recommendations, not enough chemical data, etc. Honestly speaking, I'm a huge techie guy and love my gadgets but I find a spiral bound paper notebook and pencil (or pen) works best. No need to boot up a computer and run Excel, or accidentally drop my phone in the pool (it has happened to people), etc. I just sit on my back porch table with my test kit, phone calculator and notebook and spend less than 30mins doing all the tests that are necessary. My notebook sits by the back door that leads out to the pool in a nice, decorative wall rack used for holding magazines, etc. "Old School", in this instance, really works just fine.
    Matt
    Dec 2015
    12
    Re: Pool School
    Sounds good! Looking forward to doing this on my own. Pool was just finished in Nov and I started using a service because I was traveling in Dec. Starting in March I am going to take it over. Test kits have been ordered!
    May 2015
    13,231
    Re: Pool School
    Careful with using the service guys. You'd be surprised how quickly and easily they can screw up a pool. Get your test kit now and start checking your water. Confirm with the service guy exactly what he plans on adding. Do not let them run your stabilizer (CYA) up too far or else your only way to fix it is to drain water and refill. For you CA folks, that can be an expensive proposition.
    Matt
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    Re: Pool School
    With you being in CA and lack of water you REALLY need the test kit now. The only way to "fix" high CYA is draining and refilling water.
    Matt has the right idea......work with your pool service to manage your pool as much as possible until you are done with your travels.
    Kim
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Re: Pool School
    Matt, have you tried Pool Pal? If so, what problems did you find with it.
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    May 2015
    13,231
    Re: Pool School
    Android-only app would pose a huge problem for me as I'm an iOS user
    Matt
