Results 1 to 10 of 10
Thread: New pool owner needs help in So. Cal.
    Dec 2015
    Chino/CA
    203
    Recently bought a house with an IG pool/spa, need help with the following items:
    Can you please help me identify what equipment I have, specifically what type/kind of pumps do I have? Heater brand/type? I know the model of filter I have.
    I also have questions about my Hayward Pool Vac Ultra, has anyone rebuilt one of these?
    My spa/blower has a pneumatic air switch, how hard/easy is it to convert over to something else?
    Apr 2013
    Sacramento, CA
    2,769
    Re: New pool owner needs help in So. Cal.
    Welcome to TFP!
    Can you give me a picture of the two plates on the pump body and the one on the motor.
    There appears to be a second pump or blower motor also can we get a picture of whatever plate is on that and a picture of the whole thing.
    Just a guess but the main box controls the pool pump and switches on the right the lights and the spa. The heater is controlled by the controls on the heater? Correct?
    Dec 2015
    Between Orlando, Florida and Spain
    5
    If you know the year of construction it could help also
    It seem like this one https://www.youtube.com/watch?v=oxDp4mOaT7I
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    The white pump next to the stainless steel filter is a Pentair Whisperflow. I can't see enough of the label to tell what horsepower it is. The other to the left of the Whisperflow is under a pump cover, but the strainer lid looks like it may be a Hayward pump. The pump cover should just lift off and you will be able to see what the brand and horsepower this pump has. If you can post a photo of the labels close up we can identify the pumps better.
    Love TFP? Become a
    TFP Supporter!
    The heater is a Raypak Versa. Possibly model number 335C. If it's a 335C, it's at least 22 years old.
    Support the site
    Dec 2015
    Chino/CA
    203
    Thanks for the replies and YT link everyone!!!
    I will get a picture of everything up close this weekend, working today and tomorrow full day and by the time I get home, its dark.
    But yes, I definitely know the heater and most of my equipment is older. I'm still trying to figure out how to heat my spa!!!! LoL I've basically figured out that my jets don't push out warm water, instead there is 1 water "outlet" (for lack of better terms), its not a jet that pushes out the warm water. So what I do is, I turn the heater on and isolate the spa, no suction, no jets on and push out the warm water until it heats up (about an hour) Am I doing that correctly? Does anyone know what the 2 toggle switches are for on the heater?
    Also, do you guys have any experience re-building a Hayward ultra vac?
    Chris B.
    New house w/ 28 y/o I.G. 15k gal. pool/spa, Plaster, Hayward DE-480S Micro Clear Filter, Pentair Whisperflo wfe-4, 1HP (Main Pump), Hayward SP2815x20 (Pump for spa jets), Versa Pool Heater, Hayward Pool Vac Ultra, TF-100 Kit
    One toggle switch should be on/off and one should be to select which thermostat to use. The dual thermostats are so that someone can use the heater for a pool/spa combo and set two different temperature settings.
    Support the site
    Dec 2015
    Chino/CA
    203
    Thanks JamesW!
    Does anyone know if I can convert my air switch over to something else?
    Chris B.
    Dec 2015
    Chino/CA
    203
    Ok, here are some more pics of my setup:
    Chris B.
    Dec 2015
    Chino/CA
    203
    Anyone?
    Chris B.
