Results 1 to 7 of 7
Thread: How can I tell if this pool is resin? I want to be able to run Salt Water
    Dec 2015
    Hamilton
    17
    Question How can I tell if this pool is resin? I want to be able to run Salt Water
    Here is a link to bigger pictures: Pool - Album on Imgur
    Anyway to tell if this is a Resin Pool? I want to be able to run Salt Water, but the seller says that they don't know if it is Resin. They also don't know the make or model of the pool because it was there when they bought the house.
    Any help out there?
    THANKS!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,626
    Re: How can I tell if this pool is resin? I want to be able to run Salt Water
    Tap the top rail with your ring. Does it sound like metal or plastic? Metal will TING where plastic will plonk (I hope this makes sense)
    Also look at the bottom "track" the walls sit in. Do the tap test again.
    Kim
    Casey's Avatar
    SW PA
    10,457
    It is not a resin pool. Resin is just another name for plastic.the only thing that would be resin is the top rails and the bottom track that the pool sits in.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    But, with all that being said many folks use salt with non-resin pools. Where are you getting your information from?
    Support the site
    Dec 2015
    Hamilton
    17
    My understanding is that you cannot run salt unless the pool is all resin due to rust.
    I was hoping that because of the design on the side, it might be a plastic pool. I've never seen above ground pools with those paint jobs unless they are plastic. But then again, I don't know anything about pools. So thats what I'm here.
    Jul 2012
    Tallahassee, FL
    30,626
    My above ground pool is all resin except the walls. The walls are said to be rust proof but.............I am not willing to take the chance with salt as much as I would like to.
    Kim
    May 2014
    Franklin, NC
    9,196
    Quote Originally Posted by thegoat54 View Post
    The chlorinated water it is filled with is almost, if not just as corrosive as the small amount of salt in the water. If the pool is made with a lesser grade steel it is going to rust, salt or no salt.
    Support the site
