Results 1 to 11 of 11
Thread: foaming on pool water
    Dec 2015
    Largo, Florida, USA
    13
    Lightbulb foaming on pool water
    Hi,
    How can I make more and smooth foam on pool water. I have tried some things but could not find smooth foam on pool water.
    30,432
    Re: foaming on pool water
    Forcing your pool water to produce foam is generally not a good idea. Please read "The ABC's of Pool Water Chemistry" up in Pool School
    Dec 2015
    Largo, Florida, USA
    13
    @duraleigh, Thanks for advising, actually I want to do something extra for my kids.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    I would buy them one of the those big bottles of bubbles from walmart and let them have fun in the yard!
    If you want them to play IN bubbles use the bathtub.
    Not a good idea to add stuff to your pool. You could cause problems with your balance.
    Kim
    30,432
    How big is your pool?
    Dec 2015
    Largo, Florida, USA
    13
    @Kimkats, I heard something like that normally bubble stuff cause balance problem. Anything which produce bubbles but not cause any balance problem.
    @duraleigh, Almost 7000 gallons.
    Jul 2012
    Tallahassee, FL
    30,672
    Not that I can think of Any kind of soap will mess with the PH and TA. Who knows what it will end up doing to the filter.
    Kim
    30,432
    7000 gallon pool is too big to mess up by putting stuff in it that is bad. I thought maybe you had a tiny, tiny pool that you could dump easily.
    Forget the foam.......you will be causing yourself more problems than it's worth.
    Aug 2014
    Houston tx
    2,525
    Maybe there is some kind of toy you could buy that they could use to produce bubbles just from the water. Thinking along the notion of when you blow into a straw in a glass and it produces bubbles... Not that this is something I do....
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Dec 2015
    Largo, Florida, USA
    13
    @duraleigh ,I also thought pool is quite big and it ll difficult for me to handle all the stuff. Pool toys maybe a better option.
    @Marlahoutex, Yes you are right, some kind of toys help me a lot for my pool.
    Jul 2012
    Tallahassee, FL
    30,672
    This thread is closed. They were a sneaky spammer!
