Thread: Multiline Pipe Configuration
    Dec 2015
    Southeast, PA
    42
    I have noticed some members reference the importance of having separate pipes for skimmers, returns, drains, water features, etc. to the pad. A great thread referencing this is here. Can anyone tell me if the below picture is a multiline configuration? It seems like it is, however every pipe doesn't have a separate valve.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,510
    Re: Multiline Pipe Configuration
    Could you label them please. I see the writing on the pipes but cannot read it.
    Kim
    Dec 2015
    Southeast, PA
    42
    I cannot read all of the pipes either. The two pipes sharing the same valve on the left are labeled return. The two pipes in the middle sharing the same valve are labeled deck jets. The 2 pipes sharing the same valve on the right are labeled skimmer and drain. That's all I can read from the picture.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    It is difficult to tell from the picture and lack of info. Do you have a spa?
    Your configuration does allow you to isolate each pipe. Its just a matter of more information on the details of your pool, spa, returns, and water features.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Dec 2015
    Southeast, PA
    42
    This actually isn't my pool. My PB has a ton of pictures of past builds and I have noticed all of the pads have a configuration pretty much like this one. I figured why not post a picture to find out if it is a multiline configuration? I want to make sure I have a multiline configuration when my pool is installed. Based on the diagram in the other thread, it seems to me like it is a multiline configuration in the picture with the exception that all of the pipes do not have separate valves.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    I would agree with that but each line does indeed have its own valve. The threeports allow for either line to be closed, or both lines closed off completely. At any rate, it looks to be a good set up.
    -Brian-
    POOL BUILD
