Results 1 to 11 of 11
Thread: Hot tub pump repair...how much?
    Jul 2012
    Herndon, VA
    419
    My hot tub pump needs a relatively simple repair, from what I'm guessing.
    It started leaking slightly, which means one of the seals needs replacing. Now, it is making a high pitched noise, meaning the bearings need replacing.
    I've found the kit online for $50, and videos as well on youtube which make it look relatively easy.
    Anyone know from experience how much it would cost to have a "pro" do this repair?
    Should I just suck it up and do it myself?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Dec 2015
    St. Louis MO
    10
    Re: Hot tub pump repair...how much?
    Most "pros" will not rebuild your pump motor due to warranty issues and low replacement parts costs. You can generally find electric motor rebuilders who will do the work, also without a warranty in most cases. I would recommend pricing replacement motors and rebuild the pump (seal, gaskets) yourself. Having done hundreds of these over the years, I would not recommend that you try rebuilding the motor yourself unless it is for fun, as you will likely have to buy a new one when done in any event.
    20+ years industry experience, pools and spas. Missouri to California.
    Jul 2012
    Herndon, VA
    419
    I ordered the pump rebuild kit.
    The motor still runs. Shouldn't I still be able to use the motor if I replace the bearings and shaft seal in the pump?
    Dec 2015
    St. Louis MO
    10
    The bearing that are making the noise are in the electric motor and have been damaged by corrosive water leaking from a faulty shaft seal onto the bearings. I do not recommend that you rebuild the motor yourself, the pump (wet-end) is quite simple and should be no trouble.
    Jul 2012
    Herndon, VA
    419
    The motor is a ge 5kcp49wn9070x.
    First result from google:
    Spa Pump replacement for PUUMS2602582F 1016174 1016184 PUUMSC2602582F, 1016159, PL342, 1016160, PL343, PL389, 1016167, PL388, 1016166, puumsc2602582fds, cal spas pump, cal spa pump, 5KCP49WN9070X, 1016170, 5kcp49wn9070x
    This is a different pump, but says it can replace the one I have.
    This site is where I bought the pump rebuild kit from:
    Cal Spa Pump Model PUUMSC2602582FDS Need Impeller and Seals - Pump Repair Supply
    The site has videos linked to it to help you repair the pump yourself:
    https://www.youtube.com/user/ThePumpGuys/about
    It will cost $345 to have that new pump sent to me....
    the rebuild kit is $50...
    Oct 2015
    Austin, TX
    83
    I agree with RDavis. I've tried to replace bearings before on various devices and it never goes as well or lasts as long as you think it will.
    I had a similar situation to your on my hot tub except that the motor had fully seized when I took over the hot tub. I am a guy who likes fixing stuff and I decided on the whole new motor and wet-end, on the basis that I could see that the other motor and wet-end looked much newer, and that if one was going then the other was probably likely to go soon. As it is, it was a "whole bucket of curse words" job because the motors are heavy and not in a very accessible position, and I had to cut out various bits of plumbing as I think someone had attempted a previous repair with some kind of glue.
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    Jul 2012
    Herndon, VA
    419
    Jul 2012
    Herndon, VA
    419
    Ugh, this thing sounds horrible. The new motor/pump won't be here until Friday. Hoping this current motor holds on until I get a chance to replace it.
    Jul 2012
    Herndon, VA
    419
    So the motor/pump assembly arrived. And from the looks of it, it's not going to work because the hump thing (run capacitor?)on top is about an inch higher than the clearance allowed by the heat exchanger. ARGH!!
    This is the old motor:
    Cal Spa Pump Model PUUMSC2602582FDS - Pump Repair Supply
    The new motor is model # puumsc2602582f:
    What to do? Does this mean that I'm SOL?
    Oct 2015
    Austin, TX
    83
    Extra bucket of curse words
    The motors are *supposed* to be similar sizes. You said that your old unit was an 5kcp49wn9070x - what you bought says it replaces 5kcp49wn9070x - so I would say that this is a problem that the seller needs to fix.
    Marc
    Jul 2012
    Herndon, VA
    419
    Update...
    I had a spa repair service come out to do the installation of the replacement motor/pump assembly.
    He wound up unscrewing the screws that attached the capacitor cover, leaving the capacitor dangling so that the pump would fit. He put the cover back on top of the capacitor, just not screwed in.
    $120 for him to do the installation, but I just felt better that it was done right and over with.
