Thread: Tree Trimming left debris in pool - now having issues
    Dec 2015
    Corpus Christi, TX
    1
    So check it out. We have huge oak trees that were recently trimmed and the debris was in the pool too long. My flow stopped. I looked at videos on youtube and came across how to fix the impeller. The impeller was broken, so I changed it with a new seal. The motor is turning the impeller but it wont prime and the motor shuts off about 20 seconds after running. Can someone tell me what to do next?
    PoolMes
    22,000 gallon salt water pool with spa.AO 2 hp motor, w challenger pump. Polaris bottom feeder. Sand filter. Gas heater for spa and pool. Bubbler. 2 timers - one for main pump and one for Polaris. Salt controller is computer on wall. Salt cell is rated for 20K+ gallons.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    Re: Tree Trimming left debris in pool - now having issues
    If you didnt do it already, try priming the pump with a 5 gallon bucket. That often will get it going.
    Divin Dave,
