Results 1 to 15 of 15
Thread: Liner floating
    Jun 2014
    Rogers, AR
    428
    Liner floating
    With all of the rain the last couple of days my liner took a hit.
    I ran two hoses and was able to keep the pool from overflowing but the liner is floating all around the pool and the shallow end has come out of the track and is floating pretty bad. I can't see the full damages under the cover so I am waiting for the pool company to open but I need to prepare myself mentally for the damages.
    The pool is closed for the winter, the liner is less than two years old. The water level is to the top of the skimmer box. I have read these kinds of threads before so I understand the process but I am unsure of a couple of things. Do I keep lowering or stop? Can anything even be done this time of year?
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Liner floating
    Is the liner ripped?
    Two primary causes of floating:
    1. Groundwater
    2. Liner leak
    (3) A combination of both.
    Groundwater is resolved by removing the surrounding groundwater either with a french drain, drywells or a combination of both. Where is the water table in your yard? If it is above the bottom of the pool you have a problem. If its groundwater lowering the water in the pool probably won't change much.
    Liner leaks are repaired by patching the rip or hole (or replacing the liner) and then removing the offending water (with a vacuum usually).
    You want to figure out now what is occurring so you can resolve the problem.
    Aug 2014
    Northern IL
    4,615
    Re: Liner floating
    Keeping water in the pool puts outward pressure on the liner so don't lower it too much at this point. I am so sorry for your new liner. That stinks.
    Jun 2014
    Rogers, AR
    428
    Re: Liner floating
    It's all ground water. We just got swamped and this area is in a state of emergency.
    I called my pool company and they said they were starting to get calls.
    The liner doesn't appear to be ripped, they told me to lower it to the bottom of the skimmer. They can't do anything until the ground water goes down. They are going to drain and re-seat the liner.
    Aug 2014
    Northern IL
    4,615
    Re: Liner floating
    Okay. Gotta follow their advice. I am sorry for your troubles. Remember that as the groundwater recedes, your pool level will lower on its own. The water behind the liner has probably already caused your pool to overflow a bit so you have less water volume in a smaller "container".
    Dec 2015
    St. Louis MO
    10
    Re: Liner floating
    That is exactly right. We have had liners floating all week from ground water. Most liner pools, believe it or not, are not water-tight behind the liner and ground water can and will seep in behind it. If the liner is not damaged they should be able to re-install it in the spring. Resetting a liner in the cold is problematic as it looses its flexibility and all liners stretch into place with water weight.
    20+ years industry experience, pools and spas. Missouri to California.
    Jun 2014
    Rogers, AR
    428
    Re: Liner floating
    Quote Originally Posted by RDavis View Post
    I asked them about it fitting correctly if they do it now and they said it didn't matter. There is no guarantee it will work either now or in the spring.
    Perhaps I should have them wait then? I already had my opening scheduled for 3/22. I assume it will be too cold then too. Last year I opened on 3/23 and the water temp was 47 degrees.
    Aug 2014
    Northern IL
    4,615
    Re: Liner floating
    It's the air temp that's important. Sunlight helps too.
    Jun 2014
    Rogers, AR
    428
    Re: Liner floating
    Quote Originally Posted by MarianParoo View Post
    It is still pretty cold here in March. Our rainfall totals came in...9.98" in two days.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Liner floating
    Your liner will settle back into place when the ground water recedes. It may settle with wrinkles in the floor or walls and those should be fixed when the water and daily temps are warmer. If this was an unusual amount of rain for your area and you have had this pool for years without ground water problems then you can wait for warm weather to reset the liner. If you have had ground water problems before you may want to look into making drainage improvements to divert the ground water away from the pool.
    Love TFP? Become a
    TFP Supporter!
    Aug 2014
    Northern IL
    4,615
    Re: Liner floating
    Well, no need to open early (before water hits 60 degrees)... You may be getting new water if they do drain it.
    Jun 2014
    Rogers, AR
    428
    Re: Liner floating
    This was unusual. My pool is actually deeply sloped away from the pool on two sides.
    I was able to look under the cover really well today. The shallow end is totally floating and pulled away from the track. It goes down the incline to the deep end about a third of the way. The bottom and about 1/2 up the sides of the hopper are fine in the deep end. The top half of the deep end are floating but the liner is still in the track. The liner is pretty stretched.
    I am going to call the pool company tomorrow and tell them I want to wait and cancel my opening.
    They like to get an early start to the season and start opening in March. They give a $50.00 Gift Card if you do it. The GC comes in handy so I always agree to a March opening.
    Aug 2014
    Northern IL
    4,615
    Re: Liner floating
    I am again, so sorry. They will most likely need to repair the under-liner base also, so I am glad you are waiting for warmer temps in the spring.
    Jun 2014
    Rogers, AR
    428
    Re: Liner floating
    I can't believe what a difference a week makes. Yesterday the liner was really starting to settle in and today it was all the way re-seated with zero wrinkles.
    My pool guy came out today pulled the cover back and checked it over really well and and put the liner back in the track. A couple of corners were loose so they tightened those back up as well.
    They said I was really, really lucky that it re-seated itself so well.
    Aug 2014
    Northern IL
    4,615
    Re: Liner floating
    Wow!!! That is so awesome!!!!! You should buy a lottery ticket!
