Results 1 to 19 of 19
Thread: best place to purchase acid to lower PH
    Dec 2015
    Krugerville, TX
    23
    In the past couple months ive had my pool i picked it up at Leslies. is there a better deal or place to get acid to lower pH?
    20yr old,14k,IG,Plaster,Hayward Pro-Grid 60sqft, Hayward DE Separation tank, Hayward Multi-port Valve, Whisper-flo single speed 1.5hp pump,Hayward XL concrete pool suction vacuum, Polaris P340 (Leslies Pool model), Still working to get a test kit, Leslies Power Powder and Leslies 3" Tabs.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,515
    Re: best place to purchase acid to lower PH
    I get mine from Lowes. I don't know if it is the best price BUT it is the easiest for me to get to so that counts for me. Make sure you get the 31% out in the garden shop area. There is a "low fume" one that costs the same BUT is half the %!
    Kim
    mas985's Avatar
    Pleasanton, CA
    11,737
    I use to get mine at Leslie's because Lowes and HD here went exclusively to the 14% pool acid at the same price as Leslie's' for 32%. However, they also have 32% in the paint isle which is now at a better price than Leslie's so that is where I get acid now. It pays to shop around.
    Mark
    Oct 2015
    Katy/Texas
    411
    Lowes in the paint section sells 31%. Bleach, borax and baking soda from Walmart.
    only thing I get from the pool store is bad advice😜
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Aug 2014
    Northern IL
    4,615
    If you have Menard's, they are by far the cheapest up here. $3.99/G for full-strength in the paint dept.
    Dec 2015
    Krugerville, TX
    23
    Quote Originally Posted by kimkats View Post
    Kim
    I get muriatic acid correct?
    Oct 2015
    Katy/Texas
    411
    Yes.
    Dec 2015
    Krugerville, TX
    23
    Quote Originally Posted by WASP View Post
    only thing I get from the pool store is bad advice
    I used bleach instead of the power powder shock that i got from leslies correct? whats the borax and baking soda for again?
    Dec 2015
    Krugerville, TX
    23
    We are getting a lot of rain in North Texas, is it ok to start SLAMing my pool because overnight, it turned a shade of greenish blue.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by abishoff View Post
    Depends, did you get a test kit?
    Support the site
    Dec 2015
    Krugerville, TX
    23
    Quote Originally Posted by tim5055 View Post
    it is being shipped. im going to stop at leslies for quick test.
    Aug 2014
    Northern IL
    4,615
    When is it due to arrive? We don't like messing with recommendations without good test results.
    Dec 2015
    Krugerville, TX
    23
    I ordered over the holidays so idk when they'll send it off, probably it'll ship out tomorrow.
    Dec 2015
    Krugerville, TX
    23
    From Leslie's
    FC 3
    Total Chlorine 3
    CH 180
    CYA 80
    TA 120
    pH 8
    TDS 600
    Pho 150 (he said this was high)
    They sold 2gal of 31% muriatic for $16 so I got that.
    Aug 2014
    Northern IL
    4,615
    For now, just ignore the phosphate and TDS numbers.
    Dec 2015
    Krugerville, TX
    23
    Quote Originally Posted by MarianParoo View Post
    Looks like I my CYA is too high... but there isn't much I can do expect drain and refill right? We are having so much rain hopefully it will balance out. For now I guess just shock to match the CYA at 80?
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    882
    Just wait for the test kit. Pool store testing for CYA in particular is notoriously inaccurate.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Aug 2014
    Northern IL
    4,615
    Agreed! You would be safe to bump up the FC to target levels, but wait for your kit on the slam.
    Would you please keep your signature in each post? It helps us from back-tracking on the thread or even remembering if you have one. Thanks!
    Also, do you know where to find info on your "target" FC? Let us know if not.
    Jul 2012
    Tallahassee, FL
    30,515
    Hold off on doing anything until you get your test kit.
    IF you feel as if you HAVE to do something you can put a jug of bleach in to keep the pool from getting worse.
    I am going to share a couple of links with you.
    This one will talk about the chemicals we use and what we use them for.
    This one talks about the levels AFTER your pool is clear
    This one talks about how to SLAM when your kit gets there. The MOST important part is Maintain as in maintain the FC at or just above SLAM level.
    Pool School - SLAM - Shock Level And Maintain
    AND here is the biggest and best link-----the whys and hows of TFP!
    Kim
