Thread: air bubbles in pool
    Dec 2015
    SEBRING
    4
    air bubbles in pool
    Not sure the gallons. It is 12x24 starts at 3ft and descends to about 6ft. It is an IG. plaster. Hayward star clear plus cartridge filter, Hayward max-flow xl pump, fill pool with city water. And also have a Hayward chlorine feeder. Model# cl200. Also have a polaris pressure cleaner booster pump. Water level is fine, and no bubbles in pump filter and still air when i turn the polaris pump off. LOST AND CONFUSED where the air is coming from.
    Brian
    Aug 2014
    Shallotte, NC
    693
    Re: air bubbles in pool
    Where, in the pool, are the bubbles evident? Are they coming out of the return jets?
    Dec 2015
    SEBRING
    4
    Yes coming from jets. But none in the pump filter.
    Brian
    Aug 2014
    Shallotte, NC
    693
    I suspect a leaking pump seal, but I'm going to include this link to help eliminate some other potential issues.......
    Apr 2013
    Sacramento, CA
    2,769
    I suggest you read this pool school article: Pool School - Suction Side Air Leaks
