Thread: Need help from intellitouch pros
    Jun 2014
    CA
    38
    I have a two speed pump and would like to have two valve positions for high and low while in pool mode. How do I accomplish this? It's not obvious in the manual.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: Need help from intellitouch pros
    Can you explain in a little more detail? What exactly are you trying to do? Can you also post a picture of your pool equipment?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Did you have a 2 speed relay installed on the Intellitouch control panel? You will need a two speed relay. And you will need another valve actuator other than the two for the pool and spa function.
    You will need to do the following once the relay is installed.
    This explanation is with the assumption that you are trying to use the high speed to control say a water feature.
    Assign the high speed to an Aux:
    Go into menu/setup/equipment/2-speed pmp/
    You will now get 8 boxes that display "none"
    select one box and begin to scroll through aux's till you get to the aux you want to use for the high speed of the pump. Note: When 2 speed is selected or used, low speed is then reserved for "pool".
    Hit save, back, then exit.
    Assign a valve to the high speed aux:
    menu/setup/advanced/configure valves/
    Choose which ever valve you want to use for the "water-feature", A or B, and begin to scroll through till you get the aux you want to use (use same aux you selected for the high speed).
    Again, hit save, then exit.
    If you're wanting to use the high speed for a spa spillway, that works, but a slightly different setup.
    Factory Warranty Station for:
