Thread: Cleaning concrete tips?
    New Jersey
    98
    Had my pool installed little over a month ago. On one end where a few branches hang over have a few small brown stains from tree. Have a few questions.
    1. What have you found to clean spots the best. I have a pressure washer but dont want to use it yet on the nice new concrete.
    2. Should I wait a certain amount of time since pour to do anything?
    3. Has anyone sealed regular concrete...does it help?
    14 x 32 Fiberglass Pool 10K gal. Hayward Pump and Sand Filter. Autopilot SWG Dig 48 and Heat Siphon 3.25sx Heat Pump.
    The Pool Calculator
    Chlorine/CYA Chart by Chemgeek
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    Diluted bleach (1/2 to 1 cup bleach to a gallon of water) and a stiff brush will work.
    best concrete cleaner
    The best concrete cleaner (for regular concrete) is also a pool chemical most have on hand - dilluted Muriatic Acid - mop it on, let it sit for a few minutes - it will foam like peroxide on a cut, then rinse it off. Concrete will look brand new.
    Mar 2007
    Ontario
    211
    How much do you dilute the muriatic acid? Would the 1 cup per gallon work?
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    Muriatic acid would be my concrete cleaner of last resort. It actually dissolves the concrete and so will erode any anti-slip profile, such as a broom finish, that you have.
    Bleach will remove most organic stains (e.g. leaf and acorn stains).
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Cleaning concrete tips?
    Yup, seven years old but the question is how much bleach to a gallon or water do you use for cleaning concrete ? Mine hasn't been washed well for years and I'd like to soak it down with something and pressure wash it.
    Solar Blanket, Well Water, Borax Added. 68
