Thread: Broken Fitting
    Aug 2013
    Mansfield, Texas
    72
    Broken Fitting
    While attempting to replace the pool side connection for my pressure side vacuum I broke the fitting that screws into the wall. Any trick to getting these things out? This is the threaded fitting that screwed into the pipe in the wall.
    There was a rectangular hole in the back of the fitting and I attempted to put a wrench that fit in that rectangular hole into the hole and unscrew the fitting but the hole just disintegrated.
    Next I tried to use the two little bumps in the fitting that keep the vacuum hose attached and they broke off.
    I used a hammer and a large flat punch to try and get the part to turn but there was very little surface to tap against and that broke off.
    Now I am stuck with a threaded pipe with a substantial part of the fitting left in the hole and no way to connect a vacuum. The bottom of the pool is quickly getting filled with dirt. Any suggestions would be much appreciated. By biggest concern is damaging the pipe in the wall. I assume that meands the pool has to be drained down past that fitting, concrete cut out, the fitting fixed and then the pool repaired.
    Thanks again and Merry Christmas.
    15,000 gallon plaster pool with spa and water fall, 250 Pentair MiniMax Plus Heater
    Nautilus FNS FIberglass D.E. Filter 48 Sq ft, Leslie's DPD Complete Chlorine Kit + TFTestkits Chlorine & CCs Kit.
    Oak trees overhanging most of pool
    Aug 2013
    Mansfield, Texas
    72
    Re: Broken Fitting
    Never mind. I got it.
    Just in case someone runs into this issue I have a couple of solutions now. One is to take a PVC coupling for a one inch pipe and cut two grooves in it to match the little nipples inside the wall fitting. You can stick this in the wall fitting and use a strap wrench wrapped around the coupling to turn the fitting out. On mine the nipples both broke off when I did this. So I had to take a hacksaw to it. I broke the blade in half and made a handle by wrapping duct tape around one end. Then I cut two groves in the fitting. This is where you should use caution. Saw a few times and then look at your grove. Keep sawing and checking until you can just see the threads in the grove. Cut two groves about a 1/4" apart. Then take a flat screw driver and pry the piece of fitting between the groves out. Once you break a big chunk of that out you can fold the rest of the fitting up and pull it out.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,478
    Re: Broken Fitting
    Sorry it broke but thank you for sharing your fix.
    Kim
    Re: Broken Fitting
    Thanks for the advice. Running into the same problem. This is the 2nd time in 2 years. Wondering if I should just buy a huge wrench. There has to be an easier way?.
    Aug 2014
    Shallotte, NC
    693
    Re: Broken Fitting
    Jul 2015
    Central Valley CA
    1,107
    Re: Broken Fitting
    Quote Originally Posted by roger4142 View Post
    Teflon tape might be a good idea when installing, usually not used/needed on PVC but a wrap or two might keep the fitting and pipe from seizing up for an easier replacement longterm.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
