Thread: air bubbles in pool jets
    Dec 2015
    SEBRING
    4
    I have air coming from somewhere and dont know where?? The skim baket has no air in it and acts like it is running right, but cant find where the air is coming from. Any help is greatly appreciated
    Brian
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: air bubbles in pool jets
    Welcome to TFP!!
    The first step is to ask yourself, what have I changed or messed with lately. Very few things just "happen".
    It would help us if you would add the following information to your signature
    • The size of your pool in gallons
    • If your pool is an AG (above ground) or IG (in ground)
    • If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    • The type filter you have (sand, DE, cartridge)
    • If you know, tell us the make and model of your pump and filter.
    • List any other equipment you have: SWG, second pump, etc.
    • Please mention if you fill the pool from a well or are currently on water restrictions
    Information in your signature will show up each time you post. Signatures need to fit on five lines. It is fine to put several bits of information on the same line.
    Support the site
    Dec 2015
    SEBRING
    4
    Not sure the gallons. It is 12x24 starts at 3ft and descends to about 6ft. It is an IG. plaster. Hayward star clear plus cartridge filter, Hayward max-flow xl pump, fill pool with city water. And also have a Hayward chlorine feeder. Model# cl200. Also have a polaris pressure cleaner booster pump. Water level is fine, and no bubbles in pump filter and still air when i turn the polaris pump off. LOST AND CONFUSED where the air is coming from.
    Brian
