Results 1 to 16 of 16
Thread: Polaris 360 getting stuck
    Dec 2015
    West Sacramento
    8
    I have a polaris 360 that has been working fine for 5 years. It started getting stuck in the same corner and would not back out. I have completely rebuilt the unit, replaced the back up valve and the same problem is happening. The swivels appear to be fine and there is no leaks in the hose. I am going absolutely crazy trying to figure this out. I have cleaned all filters and clean the hose filter often. Wheel RPM is 28. Any help would be appreciated. Thank you
    Apr 2013
    Sacramento, CA
    2,769
    Re: Polaris 360 getting stuck
    Have you thought about a replacement hose? Nothing stick or rubbing a wheel?
    Dec 2015
    West Sacramento
    8
    I have thought about a replacement hose but at this point everything I have thought of I have replaced and that has not worked. All the wheels spin when stuck in the corner. Thanks
    Oct 2015
    Katy/Texas
    411
    The reverse valve must not be cycling if the unit stays in the corner. I just replaced my reverse valve and when it activates it makes the unit fly through the pool.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Dec 2015
    West Sacramento
    8
    I replaced the valve. I thought the new valve was not working but it is cycling.
    18K pool, gunite, Jandy CL460, (2) Jandy JPH1.0 pumps, waterfall, Polaris 360 cleaner, Fafco solar panels with 1.5hp pump
    Oct 2015
    Katy/Texas
    411
    Are you saying that when the reverse valve cycles the unit does not get pulled away from the obstacles?
    Dec 2015
    West Sacramento
    8
    That is exactly what I am saying.
    Oct 2015
    Katy/Texas
    411
    Either you reverse valve is NOT working or you do not have sufficient water flow from your pressure cleaner outlet. When the backup valve cycles, it will pull the cleaner across the pool.
    Dec 2015
    West Sacramento
    8
    Just checked it. It seems like it has enough pressure to back it out but it clearly isn't so it doesn't. What in the unit itself would cause insufficient back pressure?
    Oct 2015
    Katy/Texas
    411
    Do you have a separate pump that supplies the unit?
    Dec 2015
    West Sacramento
    8
    Yes. I am in the pump business and the pump is working fine.
    Ellington, CT
    262
    I know nothing about this cleaner, but one comment that you made doesn't seem to me to have been addressed.
    Quote Originally Posted by Davidm2262 View Post
    Does this mean that the wheels are spinning in the correct direction to pull the cleaner out of the corner? Some type of track ion issue?
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Dec 2015
    West Sacramento
    8
    It appears that the brand new back up valve is not cycling. I pulled it apart and it looks fine. I am at a complete loss.
    Oct 2015
    Katy/Texas
    411
    Is it possible that it was installed backwards? The tapered end should be towards the cleaning unit.
    Dec 2015
    West Sacramento
    8
    Hairline crack in the hose. Problem fixed, sanity restored. Thank all
    Oct 2015
    Katy/Texas
    411
    Great. Glad that issue is off the table.
